Powering 282... reprise
Posted by: Stephen packer on 11 September 2017
A few months ago I asked about whether I should look to add a second HiCap DR to my 282 or to go to a SC.
It's feeding an active setup:
- Snaxo/HiCap (olive)
- 2xNAP200 (recently serviced)
- SBLs (recent replacement tweeters)
Sources were:
- Rega RP6 / Audiomods arm/Ortofon 2M Black /Graham Slee Reflex M phono stage.
- CD5/Flatcap2
- Audiolab MDac
The feedback was to look at the sources first; I'm mostly playing vinyl so the CD and DAC are just there for 'background music' use.
I changed the RP6 for a Gyrodec and added an SME IV (with fluid damper) / New Kontrapunkt H (with Graham Slee Elevator EXP/Reflex M). This made a lot of difference, I was very surprised at how much the cartridge lowered the noise floor; and the SME IV arm is a really nice piece of equipment to use and setup, but I'm a sucker for Engineering/design.
The bass is a lot more 'solid' and has much 'sharper edges', there's more detail and it's just altogether more involving.
I tried a few other cartridges before I bought the Kontrapunkt- AT440mlb, Ortofon 2m Black, Music Maker III. The 2m Black was best of those three, must admit I didn't really rate the MusicMaker III (it dances all over the place when I track as instructed- am sure it's aligned correctly) but it was a second hand purchase so maybe the vendor wasn't completely honest about the condition.
I'm trying to avoid looking at much else with the sources because it seems a bit pointless to spend money on something that's just there to block out background noise when I'm trying to concentrate (hifi is in my home office).
I didn't stop thinking about power supplies though... and I've bought a Supercap 2 (non DR). I've been using it to feed the 282 for the last couple of days and I think it gives a bit more depth to the music and richness to vocals (e.g. Joan Armatrading on Me Myself I.) Hard to tell really, I always wonder how much I hear is because of the money I've spent...
I think I'll review this when I put the Hicap back on the 282 while the Supercap is away being serviced (it's a 2006 model)
I do wonder whether the Supercap would be better employed feeding the Snaxo 2/4, or whether I should bite the bullet and buy a Snaxo 242, then I wonder if the Olive 2/4 is more suited to the SBLs (which I really don't want to change- except maybe for some Mk2s or SL2s ) any views on:
i) Is the Supercap better on the Snaxo than the 282?
ii) Is there any advantage to the Snaxo 242 over the Snaxo 2/4
Thanks!
