Improving metadata on HDX
Posted by: owenzel on 12 September 2017
I would like to share my latest finding on my journey of improving metadata. Some background: Link
The major issues running a HDX is that there is no way to use any software to improve metadata in the HDX MUSIC directory.
I made some test with SongKong (easy to use, designed for automated matching) and Jaikoz (much more complex, allows manual editing). Both apps are capable to read Naim's amginfo.xml and cddbinfo.txt so that data from the HDX rip is not lost. Afterwards the apps are making tag amendments from Musicbrainz and Discogs (considering UserEdits.xml is under development)
I see a light in the tunnel now to finally fix my meta data issues: I am going to move all my music from HDX MUSIC into the DOWNLOADS directory where I can edit metadata with the help of SongKong/Jaikoz.
You might find that useful as it combines the advantages of the Naim ripping engine and other Naim advantages with the advantages that these apps are offering. Demos are available so best you test it yourself.
Oliver
I do not have any connection to JThink who is developing both apps nor do I have any other advantages...just wanted to share my findings. Would like to hear what other users think.
