Non Naim Pre-Amp connection to SN1
Posted by: ScottRC on 13 September 2017
I have a Cambridge CP2 Pre Amp between my LP12 TT and SN1. I'm using the phono connections to the SN1, but I can only get any sound via the CD RCA Inputs, not from the Aux 1, which would have been the obvious choice. I don't actually intend to use a CD Player, as a reformed Vinyl user. I also tried the Din connections, with a Phono adapter with the same result.
Assuming no obvious faults with the SN1 could someone explain?
