NDS and FM capability
Posted by: m.paul taylor on 14 September 2017
I have an NDX with the FM module. I prefer FM to digital radio, I am thinking of upgrading to an NDS but it looks like there is no FM option. Anyone know anything which may cast light?
Posted on: 14 September 2017 by ChrisSU
There's no FM option on the NDS.
Posted on: 14 September 2017 by Adam Zielinski
NDS was always designed without an FM module. If you plan to move to NDS the only sensible FM option would be to get a NAIM tuner.
Posted on: 14 September 2017 by David Hendon
Many people think the FM/DAB module that is included in some NDX, 272, SuperUniti etc doesn't sound nearly as good on FM as a proper FM tuner.  So you probably aren't missing much. There are lots of good pre-owned FM tuners out there, so why not pick up one of those?
best
Posted on: 14 September 2017 by hungryhalibut
The FM on my 272 is jolly good.
Posted on: 14 September 2017 by Ravenswood10
m.paul taylor posted:
I run a NAT01 alonside my NDS and prefer it to streaming BBC Radio 3 HLS from the NDS - especially when the latter drops out due to poor connection speeds in my area (soon to end with Superfast rural broadband I'm pleased to say!). I purchased the NAT01 10 years ago and had it serviced by Naim around 4 years ago. It has to be the best  value for money Naim component I have and has peformed flawlessly in all that time .....my NDS won't last as long for sure!
Posted on: 14 September 2017 by Mike-B
I am coming around to liking iRadio over FM with the typically compressed popular stations.  It has less compression & is not limited by FM's 19kHz pilot tone filter that limits the top end to 12kHz,  maybe 15kHz at best,   & to me it is a better way for a more serious listen with these stations.  The exception where I do prefer FM is with BBC R3 which has no/low compression,  but still has the pilot tone limitations.  However R3 on a Naim system via iRadio & the BBC HLS service is pretty good & is without doubt better than most run of the mill FM receiver/tuners.  I have finally arrived at preferring R3 on FM for classical & iRadio for jazz for serious listening.   All day casual/background is usually FM via my trusty NAT-05.
Posted on: 14 September 2017 by m.paul taylor
Thank you all for the useful advice on the NDS/FM issue
Posted on: 14 September 2017 by NickSeattle
FM on my NDX is very good, the best I have owned. Even if there are better tuners out there, the NDX-FM exceeds my expectations, and is fun to use via the Naim app.
Nick
Posted on: 15 September 2017 by m.paul taylor
Thanks Nick - that is reassuring!
Paul
Posted on: 15 September 2017 by mudwolf
I ordered my ND5xs with FM, it was great in LA but I don't use it now tho I have been thinking about it because of KUSC out of LA is out here in the desert, familiar people and music. and probably too much RP in my ears.
