Snaxo 362 service
Posted by: mlauner on 17 September 2017
I have been wondering what the suggested service level is on my snaxo. It was one of the last ones produced and still sounds great but is getting long in tooth. Does it mirror Nap service intervals or NAC ?
thanks
Posted on: 17 September 2017 by Allante93
MLAUNER ยท
I am curious about the time frame for recapping a Snaxo362? It has been used for only around 9-10 years despite being older and sounds great. all my Nap 250s that have been recapped exhibited obvious signs[ running very hot or degraded sound] leading to servicing. Will the Snaxoshow signs like the amps did? I do not want to commit until I have to since it is very costly[ $1000]. Anyone had experience that can offer insights? Thanks
The filter caps in your power amps are much more vulnerable to breakdown since they are handling high ripple from the rectifiers (which is why they are also referred to as smoothing caps) in a warm to hot environment-and it is ripple and heat that are the two main causes of accelerated cap degeneration. I think you should be good for at least another 5 years on the Snaxo before considering any service. I'm not sure if routine service includes the Cermet trim pot replacements, as they are likely to get sticky over time. For the price commanded for a service, the money could almost certainly be used better elsewhere-or simply kept.
It may be that the like-for like replacement done during service replaces components with similar but higher spec ones....it has been a long standing discussion of which bead tantalum caps are the best...and certainly the latest yellow ones made by AVX are a modest improvement over the previous blue colored ones...which were maybe a tad better than the mustard color ones etc. If you are in the US, do check with AV Options about having the Snaxo serviced...they usually have a few 'extra options' that can boost performance above a standard part swap service that seem to not incur the incisive sword of the moderators.
 You are good!
Just Curious, is your 250.2 on your High Frequency Band?
BTW, Nice System!
Allante93!
Posted on: 18 September 2017 by mlauner
Ron,
Thanks for the advice. Snaxo still sounds superb but getting a bit old[your old power supply is now powering it] guess I will wait until I get actual signs of deterioration before worrying about it.
Allante,
I have CB Nap on midrange, olive 250 on treble and 250.2 on the bass. I have found that to be the best combo with my NBLs.
