Bluetooth range ???
Posted by: Orhan Arsel on 20 September 2017
My cheap Logitech bluetooth adapter has a longer range than my Uniti 2's internal bluetooth receiver. When I move my phone around the house, or go to another room, Uniti 2 music is cut off. How is this possible ?
Posted on: 20 September 2017 by David Hendon
That's the nature of wireless devices. The range is not deterministic. Bluetooth is a short range system, so isn't designed to allow you to wonder around the house in the sameway as, say, wifi is.
Best
Posted on: 20 September 2017 by Orhan Arsel
Yes, I get that. But I don't understand why my cheap $40,- Logitech bluetooth adapter has better reception than the Uniti 2's internal bluetooth adapter ?
Orhan
Posted on: 20 September 2017 by hungryhalibut
The thing is, it does, and that’s that really.
Probably means the Logitech device has a better antenna or a more sensitive receiver, but as HH says it is what it is. I doubt that the Naim unit is actually faulty although you could see what your dealer thinks.
best
Posted on: 20 September 2017 by Huge
Naim players use the minimal transmit power in their transceivers to reduce the detrimental effect on sound quality.  So reduced range but better SQ.
Posted on: 21 September 2017 by Orhan Arsel
Ok, this makes sense. Thank you.
Posted on: 21 September 2017 by Claus-Thoegersen
I have 2 lenovo machines. One cannot relyably connect  2 my braille display little more than 3 meters away and with no opsticles in the way. It works fine on the other machine. The irony is that the machine with the best connection is the cheapest of the 2 machines. >
Claus
Posted on: 25 September 2017 by mazsex
depends which version of Bluetooth each device is using...LR/2/3/energy saving/.....
