Single wiring ATC SCM11 v2
Posted by: alanbass1 on 24 September 2017
I have been using my NACA5 jumpers since I got my ATCs and always had in my mind what improvements SL jumpers might bring. I was thinking of taking the plunge but curiosity got the better of me and I unscrewed the six bolts that attached the speaker terminal plate to the speaker cabinet and to my delight saw that there were spade connectors on the wires each bolted to the rear of the speaker terminals - one wire to each. A simple job of removing the bolts from each terminal and attaching the HF and LF spade connectors to the same speaker terminal. ATC use thread lock so the bolts are resistive to coming off, and once I bolted everything tight I reapplied some threadlock to keep them secure.
The main thing is the sound and I can state that stereo imaging is more precise and high frequencies sound 'cleaner' if that makes sense. Overall 30 minutes well spent and a potential £600 saved!
