Nac 172 as pre /streamer ......in 2017 ?
Posted by: t@rmac on 24 September 2017
Hi  ,
At the moment , my setup is   Dac v1 (with Daphile player )  +  Nap 200
Make sense to replace the V1  with a discontinued nac 172 xs   ?
p.s.  I don't have any dsd in my library ,   and the 272 are too much expensive
Posted on: 24 September 2017 by magagne
IMHO, it's a side move... I suggest you to flip V1/200 and go listen the Nova, it has a better technology i.e re-written core operating system for future upgrade, and, it's a "one size fit all" box.
Posted on: 24 September 2017 by ChrisSU
I think the 172/200 is a great sounding combination, and now that it's been discontinued there are probably good deals to be had. I can't tell you how the sound quality will compare to the V1, but if you want to add streaming to your system, it's a good option.
Posted on: 24 September 2017 by charlesphoto
I run a V1 into a 110, with a microRendu for streamer (and Uptone LPS-1 for power) and iPeng as controller. Lots of options out there for the streaming part beyond Naim. Plus the 172 won't interface via USB which is what the V1 is optimized for.
Posted on: 24 September 2017 by t@rmac
nac 172  ( better pre  ) vs  dac V1  ( better  dac  with a lot of inputs ) ................is a real match
Posted on: 30 September 2017 by t@rmac
insane idea ?  and feed the V1 with a uniti core as player ?
Posted on: 07 October 2017 by t@rmac
Someone in this configuration  ?   core + dac V1 ?
