Passive Pre with a CB 250
Posted by: mikeybaby on 28 September 2017
I am currently using a passive pre with an old Chrome Bumper 250 amp. It sounds stunning. I hate not having a Naim preamp on my rack but it is alive with warmth, speed dynamics, and attack. It has replaced my 32.5 Hicap DR. I am totally dumbfounded. It sounds like a Nait5i-2 on mega steroids. Am I hallucinating?
System is Nap 250,Rega DAC Sony B-ray,SBLs,NacA5
Posted on: 28 September 2017 by varyat
Mind sharing which pre you are using?
Posted on: 28 September 2017 by mikeybaby
Exposure 2010S2 integrated (pre out) straight into the 250. XLR to 2RCA.
Posted on: 29 September 2017 by arb76
Are you sure that's passive?
Posted on: 29 September 2017 by Richard Dane
I tried a passive pre-amp on my CB NAP250 - I really didn't like it. So I'm quite curious about how your results were so different.
Posted on: 29 September 2017 by cat345
If a passive driven 250 sound like an integrated, shouldn't that mean you are not exploiting all the possibilities of your amplifier?
Posted on: 29 September 2017 by mikeybaby
Most Naimees know that a 5i-2 sounds like top of the line Naim--minus the power. The 32.5 Hicap DR sounds raw,hashy,shouty,creamy,explosive..which is musical...but the passive makes the amp sound transparent,flat,neutral,with a slightly wider deeper soundstage. A bit veiled at low low volume but superb when turned up with far less glare. I am really taken aback at how good it is. I feel less fatigue when listening with the passive.
Just ran into this bit of info : A point to be aware of, though: Although the signal path through the preamp section of the Exposure to its own amplifier section is passive, its pre-outs are driven by an integrated circuit chip, probably an "op amp" (operational amplifier), which provides a low output impedance and approximately 18 db of gain. So you are not truly using a passive preamp in the configuration you describe.
Posted on: 29 September 2017 by joerand
Interesting findings mikeybaby. I demo'd the higher powered Exposure 3010S2 for a few days in my system. Highly musical with the sweetest, purest top end I've heard from any of the half-dozen integrateds I've had home. For me the Exposure was overall too laid-back, lacking speed and attack, and I felt it really didn't hit with its stated watts. Perhaps you've found a magic combination with a vintage Naim amp. Enjoy!
Posted on: 30 September 2017 by mikeybaby
Probably preferring the Exposure at the moment due to room acoustics. I suspect the Naim will trounce it in a proper setting.
