Correct order for switching off/on
Posted by: bertbert on 01 October 2017
Hi,
as asked in the subject, whats the correct order for:
a) Nac 282
b) Nap 250 DR
c) Napsc
d) Supercap
e) Naim Dac
f) Auralic Aries Streamer
Thank you
Posted on: 01 October 2017 by winkyincanada
Always switch your power amp (250DR) on last and off first so the speakers are isolated for the rest of the switching. If you power amp isn't powering the speakers, than the rest doesn't matter.
Posted on: 01 October 2017 by ChrisSU
https://forums.naimaudio.com/to...d-power-off-sequence
Posted on: 01 October 2017 by Darke Bear
Power-off: Power Amp(s) - sources - Pre
Power-on: Pre - sources - Power Amp(s)
I like to have to Pre the last turned-off and first turned-on as some sources can present an impulse into the Pre input and damage the input coupling caps which can't happen if it is on first.
With all Naim sources then it does not matter as they all have switch-on mute.
DB.
Posted on: 02 October 2017 by Lewis
As above.
You will always get a little bit of a thump but do not be alarmed, this is perfectly normal.  It should not be a particularly loud one though!
Posted on: 02 October 2017 by Wiltshireman
What ever non Naim equipment i have ever owned I always turned the pre on first and only then the rest. When I owned Naim I only ever turned the power amp on and off, power supplies etc were always left on.
Posted on: 03 October 2017 by NFG
Wiltshireman posted:
Me too.
N
