Rack order
Posted by: Rotifer217 on 04 October 2017
I realise it's all about trial and error but I'm interested in comments regarding this rack order (from top to bottom & left to right):
RP10
TTPSU CDX2
Rega Aria NAC202
IsoTek Aquarius NAP200DR NAPSC
Well, your timing is impeccable!
Perhaps, the Heavy Weights can assist you!
Recent Thread < Naim Torque >
More than likely, they may want some additional information:
<Looks like 7 components.>
What type of Rack?
Adjustable Spacing?
How many Tiers?
Can you add more Tiers?
2 Stacks, Brains/Bronze?
Brains>Left. Bronze>Right
202. TT
Phono Pre-amp
Cdx2. PSU
Napsc. 250 DR
Is the Cdx2 bare?
What is the PSU powering?
Napsc ~ far as possible from 202, keep digital Cable apart from Analog IC.
Hope that was helpful!
If not there are tons of threads, that we point you in the right direction!
I don't have much hands on experience in tweaking and set-up!
Just a guess, and picking up info. From The Forum!
Allante93!
PS.
Cdx2>282>HCDR>3 x 250.2>Fraimlite>Briks
2 Stacks Brains/Bronze
Allante93, do you mean bronzed brawn? ![]()
The OP only has a NAP200 not a six pack! ![]()
Noticed also a 555 and two 555 power supplies.
Looks about right, you could compare with the PSC next to the TTPS. I’ve always found Rega stuff to be relatively unfussy about setup so it probably won’t mind the company.
Interested in whether this set-up sounds reasonable:
I'm beginning to think a separate Turntable wall shelf may be the way to go.
Rack is 1200mm wide so plenty of room between components.
So set up would be TT on shelf, then
Both pre-amps on top shelf, then
CD player and turntable power supply on middle shelf, then
IsoTek and power amp on bottom shelf (NAPSC sitting on floor away from other components)
| RP10 | Wall Shelf | ||||||||
| NAC202 | Aria Preamplifier | ||||||||
| CDX2 | TTPSU | ||||||||
| IsoTek EVO3 Aquarius | NAP200DR | NAPSC | |||||||
Rotifer217 posted:Interested in whether this set-up sounds reasonable:
RP10 Wall Shelf NAC202 Aria Preamplifier CDX2 TTPSU IsoTek EVO3 Aquarius NAP200DR NAPSC
Sounds about right!
150% agreed
Are you a Heavy Weight? LOL....
Allante93!
PS. 6 pack and all.
Body Builder Wow! Funny!
