Connect Naim
Posted by: vilco on 16 October 2017
Good morning,
this is my first post in your forum, and I'm very gratefull to write here.
I have got a Naim pre nac 112x + nap 150x + flatcap 2.
I want substitute the nac 112x with a new performing one preamplifier, at the moment I could proove a Nac 62 (olive series).
My question is:
Can I connect the nac 62 to the  nap 150x or to Flatcap2 ?
If I can, how to do it?
Best Regards
Posted on: 16 October 2017 by Richard Dane
Yes.  You can connect the NAC62 directly to the NAP150x (here the NAP powers the NAC) via SNAIC4.  Make sure the 5 pin link plug is fitted to the NAC62.  Otherwise you can connect the NAC62 to the Flatcap 2 in the same way as the NAC112x, via SNAIC4 - remove the DIN5 link plug from the NAC62 and use that socket.  Then SNAIC5 from the Flatcap 2 to the NAP150x exactly as you have already.
Posted on: 16 October 2017 by analogmusic
Is a NAC 62 an improvement over the 112X?
Posted on: 16 October 2017 by vilco
Thanks for the answers.
I have a friend who makes me try the NAC 62
I'm especially interested phono input.
Compared to the 112x, I get an improvement?
Wich preamplifiers do you recommend me for my nap 150x to have a real improvement.
Thanks!
A NAC62 in good fettle can perform really well - better indeed in many respects than a NAC112x.  You do lose some facilities though and no remote control...
Posted on: 16 October 2017 by sktn77a
The NAC62 was a good pre-amp..........  in its day.  I'd be surprised if you would find it an improvement over the 112x with a stageline today.  I don't think I would want the cosmetic mismatch, either.
Posted on: 17 October 2017 by vilco
Thank you
I tried the nac 62 in my system and I have to say that much but much more prettier than the 112x
At this point I have to make a decision whether to buy a nac 62 or nac 72
Many Thanks for your help.
