Calling all DAC V1 Owners
Posted by: Halloween Man on 17 October 2017
I'm hoping somene can help me. I'm using iTunes (I like it!) and considering using a little iTunes eq on some bass heavy tracks to reduce bass, the remaining tracks untouched so that playback remains bit perfect.
iTunes has a useful feature in that you can apply iTunes eq settings to individual tracks that will activate automatically during playback. The only issue with this is that you have to leave iTunes eq switched on with the 'flat' setting. I was hoping V1 owners could run this through your bit perfect test procedure to confirm if the 16/44 bit perfect test passes or fails when eq is active and switched on but set to 'flat' settings. I'm only interested in 16/44 samples. You will have to set 16/44 manually in OS X audio midi settings for the bit perfect tests to work with iTunes.
Thanks for any help!
