CB Naim Nait 2
Posted by: Shane. on 24 October 2017
Just got myself a CB Naim Nait 2. This example was serviced earlier this year. Only switched the unit on today. Sounds very detailed and tight. Hoping the sound will smooth a little bit more over the next few days.
My Rega Apollo-R CD Player, is connected to the AUX input......Perfect.
The Tuner and Tape inputs, I simply don't use. But when I select with the input selector knob to either of the two unused inputs, I get a humming/buzzing sound which is in sync with the volume. The buzzing gets louder as I increase volume.
No buzzing with the AUX input (CD Player). Also, the volume dial feels a tiny rough when I adjust. Feels like it's touching against the face. It's not a silent turn. I'm guessing this is normal? I'm afraid to attempt to pull the knob out a few mm! Don't get me wrong the volume works fine.
Bit of a novice with the Nait 2.
Thanks.
S.
