102 Logo not Lighting Up with Napsc2
Posted by: mikeybaby on 31 October 2017
Is my logo faulty or does the 102 require the original napsc? Thanks.
A NAPSC 2 should be fine. Does it light up with the paddle link plug in place and no NAPSC?
No.
I am surprised because two days ago the logo was very bright and looked healthy.
When you said ‘no’ above, can I take it that you were trying it with the 102 powered from a power supply or power amp, and with the appropriate link plugs inserted?
Yes HH that is correct. I took my Hicap for servicing and tested the pre with only the napsc with and without the plugs only to find
the logo not lighting up.
I wonder if the napsc’s fuse has gone. Is its little light coming on? I’m sure you’d have noticed if it wasn’t. And I guess you’ve triple checked that you are using the right link plugs. It’s a long time since I had a 102, but have you tied it without the napsc and powered from your power amp via the snaic 4, and with both links in place?
mikeybaby posted:Yes HH that is correct. I took my Hicap for servicing and tested the pre with only the napsc with and without the plugs only to find
Mike - what power amp were you using ?
Amp is Nap CB250...Please note also the inputs light up on the 102 but not the naimaudio logo. I will check when I get my amp and Cap back. The napsc works fine and lights up my 82's logo but when I substitute the 102, the logo and inputs light up but not the logo....problem must be the 102 logo burnt out. Thanks guys.
Sorry I botched that...when I substitute the 102 for the 82 the inputs light up but NOT the logo.
Mikeybaby, it's so long ago I can't actually recall whether the logo does light up if only the NAPSC is connected - i.e. the pre-amp itself is unpowered. Best way to check is to power up the pre-amp itself as well as the logic and control circuits. You'll need a suitable power amp (and link plug) or dedicated power supply for that. Can you do that?
mikeybaby posted:Amp is Nap CB250...Please note also the inputs light up on the 102 but not the naimaudio logo. I will check when I get my amp and Cap back.
Ah that explains a bit more. I'd wait until you get the Hicap back to confirm if the logo is a problem. As Richard says, you may need the additional 24v supply (from Hicap or suitable Power amp) to get the logo to light rather than just needing the NAPSC. I suspect that this is the case rather than a broken logo backlight.
Mikey, the 102 logo will light up only with a power supply connected. The input selectors light up only with the Napsc connected.
Got it! I was pretty sure the logo wouldnt just die. Naim is idestructible.![]()
Phew ![]()
Update. Hicap is back and yes CAT345 you are correct..it needs to be connected to light up the logo. The napsc only powers the inputs.
