What constitutes a standard set of Superline Plugs?
Posted by: Steve O on 02 November 2017
Don't worry guys it's not another loading question.
Can any of you lovely lot tell me what plugs would have come with my Superline?
I have one with the value label missing and wondered what it's value was. I thought if I email customer support and get a list of the plugs that would have come with my Superline I could find out the value of said plug by elimination. So I emailed customer support and Steven Hopkins replied with a list of plug values that only vaguely resembled my set of plugs. I queried the difference by reply and was advised to raise the matter with my dealer, which I'll do in due course, even though I am disappointed with that response.
In the meantime it would be interesting to see what value plugs you guys have.
I'm currently using a 453 ohm Airplug type I purchased separately, the other plugs which came with my Superline are:
100 ohm, 220 ohm & 500 ohm for Resistance
1nF, 5.6nF and 10nF for capacitance
plus the one that has no label which could be resistance or capacitance.
Steven Hopkins advises me I should have had:
100 ohm, 500 ohm, 1K ohm & 10K ohm for Resistance
1nF, 2nF, 6nF & 10nF for Capacitance.
What came with yours?
Posted on: 02 November 2017 by yeti42
The one with no label is a 1KΩ resistance plug, the label's fallen off. With no plug fitted the resistance loading is 10kΩ.
Posted on: 02 November 2017 by Richard Dane
Deja vu...
Superline Loading Plugs
Posted on: 05 November 2017 by Steve O
I've removed the housing of the "mystery" loading plug to inspect the contents and it's a resistive plug.
It contains 2 resistors of the same value with 6 bands and starting at the end nearest the pins they are as follows:
Yellow - Green - Orange - Black - Brown -  Red
I used a resistor calculator I found online and this gave me a value of 453 ohms (210K ohm if you read the bands from the other end).
Are these two resistors in parallel or in series or, as I suspect, is it one resistor per channel?
Steve O.
