Naim app NDX controls not working
Posted by: GrizzlyHippo on 02 November 2017
Something odd has happened. The play/pause next/previous buttons on my Naim App on iPad do not work for my NDX. They are working perfectly for all our Musos. I noticed this problem earlier tonight, checked for an update (there was one v8.5.2) and downloaded it but the same problem is there. I have restarted the iPad but no difference.
Is this a bug?
Thanks,
Tom
Posted on: 02 November 2017 by GrizzlyHippo
Also when you queue a CD it only plays the first track and because of the mentioned problem there is no way to move it on to the second tack. Frustrating!
Posted on: 02 November 2017 by Klout10
I assume that you’ve already tried to restart your NDX, router and app ?
Posted on: 02 November 2017 by David Hendon
This is not a bug that anyone else has reported and we didn't see it in beta testing. I suggest you restart your NDX as a first step.
And when you say you you queue a CD, I am assuming you mean you are talking about a CD rip playing on the NDX?
best
Posted on: 02 November 2017 by Pcd
Hi, just been playing ripped Cds on my NDX all OK.
Posted on: 02 November 2017 by Mike-B
As David said it not something reported before.   A few quick things to try:   In Settings > reset the app.   While you are in Settings, check that all the buttons are enabled in 'Other Settings'.       If that doesn't work,  delete the app, power cycle the iPad & reinstall the app.         Because the problems with NDX only (Muso is OK)  the issue might be in the NDX side,  a reboot of that might be worth a try.
Thank you everyone, restarting the NDX solved the problem. All is right again in the world.
Tom
