Is it worth refurbishing a 1990s LP12 or should I start again or give up?
Posted by: ermine on 04 November 2017
I decommissioned my LP12, Syrinx PU2 and AT something MC cartridge around 2005-ish, but there's an album I have that was never issued on CD. In the mid Nineties I recorded it as a 44.1kHz wav with a 486 PC using a Creative soundcard, and it's on my streaming system.
I recently moved, soon after getting a NAC272 and my system (272->NAP250->SBL1) has room to breathe, it's a lot more fun. I've exclusively used CD since the mid 2000s and streaming (from CD rips) and CD now. It's reasonable to assume I have lost some HF acuity since I am closer to 60 than the pushing 40 I was when I transferred that record, but I hear some LH mistracking on the end of side 2 of that digital recording along with general unclarity and mush which was probably the general purpose soundcard. Clearly my younger self was more habituated to the vagaries of vinyl but 20 years of not hearing mistracking means that grates now. It's not crackling or breakup which I wouldn't have tolerated then, but there is an increased harshness to the end. I used to hate poor tracking even more than surface noise, but it seems I dislike it even more now.
If it were just this album I'd ask a dealer to rent a good vinyl system for an hour and record the line out on my Sound Devices SD702 field recorder, but I did keep some of the vinyl that gave me most joy in my student days and my wife would like to play her records. I hanker a bit hearing once again a complete analogue signal path...
Presumably 25 years of progress has improved the technology, is an old LP12 (single speed Valhalla) a worthwhile base or can I get better for cheaper now? It has been stored in the loft in the packaging with the spacer lifting the platter from the main bearing, I guess the cartridge is probably shot by now and rubber bits of the deck. Perhaps the arm too.
Trouble is I have no idea if I'd be throwing good money after bad trying to revive a quarter-century old turntable. Is there still the dilemma between poorer tracking performance but greater transparency with MC cartridges relative to MM or have they sorted this in the intervening time? Getting it into the 272 also seems an issue, though Naim can help me with that and I already have a Flatcap on the CD5XS.
