Question - an MQA encoded stream from Tidal how should this playback via the Naim app?
So I have Alanis Morissette, MTV Unplugged 'Master' version selected in my 'My Music' Albums from Tidal.
In the Tidal app, it plays as MASTER, indicated in the taskbar, so it undergoing playback at 24/96, given that the Tidal app on Windows has MQA software decoding, allowing for the 'first unfold' of an MQA encoded track.
From Roon, it shows the playback path is for an MQA 192kHz track, which is playing over my Sonore UPnP Bridge to my NDS. Given there is no MQA software decoding in this path, the player should see a 24/48 stream.
Which is confirmed in the 'Playing Now' on the Naim App - see the 'FLAC 48kHz' format message.
So when I select this in the Naim app, i.e. the same Tidal 'MASTER' version, the MQA encoded version.
and hit play, I only get 'FLAC 44.1kHz' playback! Why?
Is this just the 16/44.1kHz version?
Why isn't the Naim app able to resolve and playback the standard 24/48 version of the MQA encoded version, provided as 'MASTER' in Tidal?
Does the Tidal support in the Naim App need to be updated for the latest 'Tidal MASTER' versions? However, these have been available for some time now.
Are we wasting money on Tidal 'HiFi' subscriptions if we can't access the 24/48 versions of these releases?
Are we, as owners, of the non-Uniti range, now dubbed 'Legacy' products by Naim, not getting the attention or product development for our existing (and considerable) investment? If a recall, there is no direct replacement for the NDS/555DR player, as yet, so this is a current product, able to be bought today.
So could you either provide support for at least the 24/48 playback of Tidal MASTER versions directly from the Naim app (ideally with first unfold performed in the software decoding, but I understand that requires MQA licenses).
Or add native Roon support across the older 'Classic' products or an upgrade path of the streamer board to enable this.
Roon will be adding software decoding of MQA tracks in due course (I would imagine, of course, I wouldn't have any insight into that!). This coupled with aTidal subscription, would give access to a complete online library of HiRes music, able to be streamed down and then 'unfolded' to provide up to 24/96. It is the 2nd and 3rd unfold, which needs the MQA DAC profile to get to 24/192 and even up to 24/384, and this requires an MQA certified DAC - any plans Naim?
Thanks, Simon.
Posted on: 18 November 2017 by Hanover33
Also interested in this topic - will Naim provide MQA support natively? There is a growing list of high end manufacturers who do such as PS Audio, Lumin, Mark Levinson, Carey Audio, Berkeley Labs, Bel Canto....
Having just purchased a Nova to replace my beloved SuperUniti, the only thing really missing is full MQA support in my opinion.
There are competing streamers/DACs/and all in ones that support both Roon Ready and MQA and many at attractive prices. Don’t get me wrong, I love the Naim sound, but are we missing something? I don’t really know unfortunately but so far are trusting Naim to get it right ultimately for their customers.
Has Naim a statement of direction on MQA?
Posted on: 18 November 2017 by simes_pep
But the unfolded stream of an MQA encoded file should be 24/48 and not 16/44.1
With Roon, at present, there is no software decoding of the MQA stream.
Playback of Roon is either through a UPnP Bridge product, which runs on a Sonore device, in my case a SonicorbiterSE, which presents as a Roon Endpoint to the Roon Core, and then to NDS on the UPnP server input (in fact the NDS auto selects that input when you initiate playback). This uses the Squeezebox support in Roon and technology developed for the Squeezebox community. It supports up to 24/192 and DSD64 (probably high too, just this is far as I need it to go).
Or I can use the USB output of the Sonore device, through a convertor and in a digital input, but I have no indication of the incoming resolution of that digital stream. Plus on the NDS you have to select the input!
My question is still why is the Naim app playing the Tidal Masters at 16/44.1 and not 24/48?
Simon
Posted on: 19 November 2017 by schuhmab
Hi Simon,
naim app still playing master tracks (like Killing Me Softly by Roberta Flack) at 24/48. Just a bit tricky to select the right version in naim app. Add the master track to your favourites in Tidal app, then select it from favourites in naim app.
Alternatively, got to the 16/44.1 album in naim app, go to similar albums tab and select the master version from that list. This should play the master track at 24/48. Not sure if there is a difference though between the new Unitis (my Atom) and the black boxes (your NDS).
Although I have to admin I don't hear a difference between the 16/44.1 and 24/48 versions on my system, I only save the 16/44.1 versions, not the masters, as favourites.
Small addition (re [@mention:1566878603923229] above): see this previous thread what our devices (and the app) display and what gets played - while they display 24/48, they actually play 13/48 (the part of the MQA data that can be decoded without MQA (unfold) capabilities).
Posted on: 19 November 2017 by simes_pep
Yes, I have ensured that the Albums selected in my Tidal 'Favorites' are the Master versions - I also have that Roberta Flack, and Pink Floyd's Divisional Bell, as I listen to these through the Tidal app, but I have the FLAC HiRes versions already so need for the Tidal streaming version, at home.
However, I have just confirmed that the NDS only playing the 44.1kHz versions of these too. The signal path through Roon, to the UPnP Bridge is also confirmed at 48kHz playback.
So the Naim app is definitely not directing playback of the Master (MQA encoded) versions to the NDS, as MQA playback without any decoding, the 'no decode' option in the following article (with Bob Stuart Q&A)
https://www.audiostream.com/co...a-decoding-explained
Thanks, Simon.
Posted on: 23 November 2017 by Stevesky
Morning Gents,
For MQA material to be accessible on a native Tidal playback solution (as implemented in Naims streaming products) the manufacturers Tidal partner account must be enabled to support MQA. As we currently do not support MQA, if a Tidal album ID is passed in that was originally resolving to a MQA encoded album, the Tidal servers resolve it to the CD variant and provides that stream instead.
When using Roon they allow browsing of the MQA content, as one of their connected devices could be an MQA enabled DAC or Roon RAAT player somewhere on the network. If using Roon native RAAT support on Atom, Star or Nova we will receive the folded stream from Roon. Decide between yourselves if they sound better or worse than the CD variant.
As for supporting MQA, we have been in discussions with MQA Ltd. but there are a few commercial hurdles which are still in the way. As it's a very expensive hobby to add features like this to a product range, we need to have confidence that there is a critical mass of main stream acceptance in a format and its financially viability in the long term.
Best regards
Steve Harris
Group Software Director
