Naim speaker plugs
Posted by: james n on 23 November 2017
Folks - does anyone know if the pins in the Unitiqute speaker plugs (below) are the same as in the normal Naim speaker plugs. As far as i'm aware, only the Ovator plugs have different plating to standard ?
Otherwise recommendations for good quality speaker plugs appreciated - the Naim ones look like Deltron but with a different solder bucket.
James
