This might be a stupid question....
What are 5 pin Link plugs, flexible link plugs or paddle plugs for, please?
Are they to configure a source/preamp/poweramp for its power supply?
Or do I need them in empty input sockets to reduce interference?
Posted on: 24 November 2017 by hungryhalibut
Assuming you are talking about a 202, you will find all connection details in the manual. If powered by 200 you need all the plugs in place or it won’t work. If using a napsc you remove the paddle plug. If using a hicap you remove the little round one.
Posted on: 24 November 2017 by joerand
My familiarity with link plugs are in the Nait XS, SN2, and CD5X; all "paddle plugs" I suppose. The units come shipped with link plugs in place and are required for them to operate. If you add a PSU the link plug is removed, disconnecting the internal power supply to the pre-amps (or for the CD5X, it's analog output power). The PSU is then connected via a SNAIC. There's no need for link plugs in empty sockets AFAIK, unless you are removing a PSU, in which case the plug is essential.
Posted on: 24 November 2017 by vintageaxeman
Many thanks for your two replies. I thought they MIGHT be interference-busting shorting plugs, similar to Russ Andrews' 'Shorties'.
I will ignore their existence then, as I clearly have no need for them with either my AV2/NAP150/NAP175 AV system, or with my other Naim units: a Superline & Hicap2, and an n-Dac & XP5 XS.
Thanks again, David
