Super Lumia - can you convert speaker to signal?
Posted by: rjstaines on 29 November 2017
Can you convert S/L speaker cable to signal cable by changing the plugs at the ends?
More specifically, I have 5m S/L speaker leads and I want to change from passive to active amplification, so can I re-terminate the 5m lengths from 4mm speaker plugs to din and XLR (dual mono leads, in fact) ? (When I say 'I' here, I mean Naim... could Naim re-terminate these cables)
...or is there a fundamental difference between the speaker version and the signal versions of S/L that I have failed to appreciate?
