Headphone amp: Naim DAC V1 vs Uniti Atom/Star/Nova
Posted by: Leidsekade on 03 December 2017
Hi there,
My friend is looking to build a hifi set-up with a DAC/headphone amp combo. I've recommended the Naim DAC V1, but I'm trying to determine if this has been 'replaced' by the Uniti Atom/Star/Nova.
I've been given conflicting advice about whether the Atom's headphone amp is as good as the V1. One hifi store owner says yes, the other says no. One also says that there's no increase in headphone amp quality as you progress to the Star and Nova.
I have actually demoed the Star and it sounded much better than expected. However, I wasn't able to do a direct comparison with my V1.
The Atom all-in-one solution would be ideal, as my friend is building his set-up from scratch. However, headphone amp/DAC sound quality is the most important factor.
If anyone can clarify the points above, it would be much appreciated.
