Qnap tvs-871 and HDX
Posted by: 2roomsor1 on 04 December 2017
hi all, its a bit of a cry for help, i am having trouble getting my hdx to back up to an external nas, the qnap tvs-87.
my system also consists of another snap that i use as a share, local to my hdx.  my other nas backs up my share nas and hopefully my hdx, however i can not get it to convert a share to a backup.
i appreciate that there are hundres of potential glitches, issues, settings
basically, the hdx will see the share on the 871,  it will allow me to change to share to a store and back again, but when i try to change to share to a backup, i get 'unable to covert share 871tvs to a backup'
any quick sanity check?
thanks
Paul
Posted on: 04 December 2017 by Klout10
Have you read this document:
https://www.lathamaudio.nl/wp-...er_backup_to_nas.pdf
Posted on: 04 December 2017 by ChrisSU
You might be falling foul of the rule that the share must be completely empty in order to be made into a backup folder.
Posted on: 04 December 2017 by 2roomsor1
i have made sure he share is empty,  still no joy?
am trying the guest angle, even though the user login is for read write.
thanks for help will update later
nothing works, the fact that it can be used as a store or a share but not a backup, am i missing something glaringly obvious?
Posted on: 04 December 2017 by blythe
What format is the Qnap currently formatted in? It may be worth re-formatting anyway, to make sure it really is totally empty and in the correct format for the HDX.
Posted on: 05 December 2017 by 2roomsor1
i have removed the share folder completely and re-created it, the option of reformatting the NAS is not an option, there are too many other shares in the data pool, 8tb of video/photos
my issue is that it can be used as a store no issue, and ripped to after the backup can not be created.
puzzling?
Posted on: 05 December 2017 by sjbabbey
Could it be a “Recycle Bin” option is preventing the HDX from accepting the folder as a backup location?
Posted on: 06 December 2017 by Klout10
Might be better to contact Naim directly ...
Posted on: 06 December 2017 by Richard Dane
Klout10 posted:
Have you been in contact with Naim support on the usual email address? If not, that's what I would suggest.
