Jriver cue settings
Posted by: meni48 on 05 December 2017
I found out that JRIVER can split CUE without having to divide it through DBPOWER, which I used to do all the time, but there is a problem when I come to play the file that it distributed on NDS it is playing only MP3 even though the file is LOSSLESS, I was looking to change the JRIVER settings to LOSSLESS and if possible to WAVE, But I have not found, maybe you guys in this forum knows the answer I`m looking for ..thank you!
Posted on: 05 December 2017 by likesmusic
It sounds like J River is transcoding. You can change J Rivers DLNA streaming settings so that it doesn't.
Tools > Options > Media Network >  --- Add or configure DLNA servers
Then under the Audio section
Mode:  Specified outuput format
Format: PCM 24bit
(or whatever output format makes sense for your DAC, but not MP3!)
Then quit and restart J River for the new streaming settings to take effect.
Posted on: 05 December 2017 by meni48
likesmusic posted:
Format: PCM 24bit
Great amazing thanks ,you really likesmusic as your nick name, it is playing on wav format, the way I always wanted
meni48 posted:
likesmusic posted:
Format: PCM 24bit
I used before asset as a server but to me jriver sound better on my nds streamer
