Having dreamed of being a Naim owner for many years, a couple of months ago I threw caution to the wind and bought a used Supernait 2 from a Naim dealer, a significant upgrade from my Arcam Solo and my biggest Hi Fi purchase ever.
Excitedly I set it up, plugged in my existing speaker cables (Audioquest Slate) and played some of my favourite vinyl on my turntable. It sounded incredible. A couple of years ago I upgraded to a Clearaudio Concept Wood from an entry-level turntable and a veil was lifted from the music. Switching to the Supernait 2 was the same again. The music became even more engaging, another veil lifted, subtle aspects of the music I had never heard before I heard for the first time, the stereo imaging and soundstaging was incredible. I was hooked. I played records with my wife and she was hooked away too, all was good with the new purchase.
I read a lot of views of the right speaker cable to use with the Supernait, many from this forum. The NAC A5 was almost universally praised so I thought I would complete my upgrade with the ideal cables also. The Supernait 2 had already blown the budget for me, so I found an older used 3.5 M pair of unterminated NAC A5 online and bought them. The dealer that supplied the Supernait gave me (FOC) a pair of the Naim terminal plugs for the amplifier end and a set of Deltron plugs for the speakers. I soldered the Naim plugs and fitted the Chord Company plugs and replaced the Audioquest and sat down with the same favourite vinyl. Unfortunately I was very disappointed. Almost all of the sonic benefits of the Supernait 2 were lost. The newly found details were lost, stereo imaging took a backward step, the music somehow less engaging. I checked that I had not wired or installed the cables out of phase, I had not. Eventually I switched cables back, normality was restored. Many years of being a fan of Hi Fi has lead me to follow my ears and that’s what I did.
I am more than happy with the Supernait 2, but puzzled about the seeming lack of performance of the NAC A5. At this stage I am making the assumption that I have done something wrong somewhere along the way, the question is what. For background, here is my system:
Clearaudio Concept Wood with Clearaudio Performer V2 cartridge
Graham Slee Reflex M phono pre-amp
Van Den Hull D102-III between phono pre-amp and Supernait 2
Dynaudio Audience 52 speakers, stand mounted.
The NAC A5 is older and one run has the Naim text and direction arrows almost completely worn away, so I guessed the direction based on the markings that were left. The other run has clear arrows on, which I installed towards the speaker. I am not an expert in soldering, at the amplifier end, based on the photos I have seen from the internet, my termination was not the prettiest, but by far not the worst. The dealer said that he thought the freebie speaker plugs may be rhodium plated, my recent research says they are nickel, which I suspect isn’t ideal. So the question is what next? I am keen to get to the bottom of the problem so I can hear what the NAC A5 can do. Any advice?
George
Posted on: 07 December 2017 by Mike-B
I would really suspect you have them wired out of phase if you hadn't said you've checked it. Even so I gonna say are you sure, are you really sure ?? How did you check this ?? I really would go over that again - do you know how to check it using a 1.5v battery ??
Re the long shot other possibilities. It may possibly be you do have a bad solder joint, but even if its not so neat I doubt a bad joint would give the effects you describe. Re banana plug pin material/plating, the Naim pins are the same material as used in the Naim amp speaker sockets so they are 100% right for the job, besides even if it was rhodium or anything different, it would not cause your problem.
Posted on: 07 December 2017 by ChrisSU
Soldering NACA5 has to be done properly. Have you read the section on it in the Forum FAQ? Alternatively, ask your dealer to do it for you.
The Naim right angled plugs are the right ones to use at the amp end, and nickel plated Deltrons at the speaker end are a good choice. Also, make sure that the stiffness of the cables is not exerting any tension on the ends, especially the amp sockets. Softening it up with a hairdryer and preforming a bend can help.
Posted on: 07 December 2017 by Stephen Tate
Hi George,
May l suggest that you take the NACA5 cables to your local dealer and kindly ask them to make them up for you. I have found the soldering, type of solder and termination technique are critical to A5 performance and it really 'is' a big deal. I have proved this to myself time and time again!!
It took me quite a bit of practice with a solder iron to get the process right over time and I have been soldering for over thirty years!!
The difference between the job being a good one or a bad one is massive in terms of performance, get it right however and everything falls into place as well as the penny and why one should be using it in the first place.
Posted on: 07 December 2017 by Adam Meredith
https://forums.naimaudio.com/to...-andamp-f-connection
Various aspects like direction, coating on plugs, etc. shouldn't be make-or-break matters.
You seem to have a decent relationship with your dealer. If he's happy so to do - I'd take the cables to his shop and (if he uses NAC A5) substitute them in a known system to check they aren't doing something disastrous.
I'd suspect a problem with the soldering. It would be useful anyway for the dealer to check this. It's one of those jobs that's fairly easy - the 50th time you do it but a bit-of-a-bugger the 1st.
If all is well with the cables and you prefer the ones you have - resell the Nackers on-line.
.....also, did you strip the insulation back until you found pristine, shiny copper before soldering the new plugs. If corrosion has crept under the insulation over time, you should cut beyond it through clean wire.
This has been a question I've raised with myself and haven't been arsed to answer.
NAC A4 used to go green like gang busters and it was considered good practice to trim back to the copper before soldering (new) plugs. I slightly wonder if the worries prompted by the visuals were necessarily indicative of actual deterioration within the working bits of the solder joint.
Since NAC A5 became semi-ubiquitous I haven't noticed that verdigris as a problem. That said, like the Queen visiting a hospital, when you work at Naim, all the cable you encounter 'smells of new paint'.
The problem with A4 was able to migrate inside the insulation. Perhaps A5 melds these two elements better and maintains airtight conditions within.
Posted on: 07 December 2017 by Lewis
Some years ago I owned Chord signature cables and ran these with my Olive system (82/180). After reading about Naca5 I tried some, and did initially find that the sound was slightly 'thinner' than with the Chord, so I do understand where you are coming from here. However, the Signature was just adding bass which shouldn't have been there in the first place.
I also ran a Supernait for a while on demo with the Signature cable, and while I enjoyed the sound it was almost a tad vacuous, difficult to explain in words. Also the S/N plays a very refined sound compared to the older Naim equipment, so Naca will accentuate these qualities (mid / treble, lots of detail).
Speaker cables can alter the sound of your system, and needs to be tried out to see which you prefer.
I would check it has been soldered properly as mentioned above, but be cautious, as there is an art to this and even dealer examples I have seen in the past have been shocking to say the least. Dr Peter is the best man for that, he did my first runs of A5 and they are excellent. Nowadays I solder my own cables as I have mastered it, however, you need a very good quality iron (to give an idea mine was approx £300). Good tools and all that...
It could be that you just prefer the sound of your AQ cables, but I would give the Naca5 a couple of weeks as it took me a while to adjust to the sound but now I really enjoy it. There is also the supposed burn in time but I equate this to relate to your ears adjusting to the sound more than anything else.
This is just my personal opinion of course
In summary, once you've checked the phasing and soldering etc, give it some time to settle into the system and see how you feel in say three weeks or so.
Posted on: 07 December 2017 by georgecart
Wow, thanks everybody for the quick responses. I did strip the cable back by cutting of the exposed ends, I didn’t want to lose too much length so is didn’t go much further back than this. Yes I did watch several tutorials on the termination of the Naim plugs before attempting myself. My iron was not as powerful as some recommended, and it was my first not 50th time of course so not perfect by any means.
I have a couple of follow up questions.
1) Say I take the cables to a dealer, can the existing naim plugs be desoldered and re-soldered or do new ones need to be used?
2) If I chose to diagnose the issue by removing the naim plugs and installing high quality crimped plugs to at least see if I like the cable and to identify which way round the unmarked run should go, what high quality crimped plugs do you recommend?
Thanks for all the help so far!
George
BTW if it’s relevant I live in Toronto, Canada
Posted on: 07 December 2017 by SongStream
I had a similarly disappointing and alarming experience when I first switched to NAC A5, and started a thread along the same lines. I received much of the same advice, with the addition of letting them burn in as my cables were brand new. They didn't burn in, I didn't adjust to them, my (now) dealer checked them out and found the solder to be a good job. But...when I bought them my situation was different, and i was not in that happy place with the system, which shares the SN2 and actually Van Den Hull D102-III (which I think are great BTW), but digital front-end. I was hoping A5 would mend something that was a bit broken, but what they actually did was accentuate the gripes, namely over emphasized top and bottom end, and worse still the stark absence of mid range grunt and warmth. They did make the sound cleaner and more defined, but also it was thin and vocals in particular were really grainy.
I still use NAC A5 with my current speakers after a re-think, and the system has had me utterly hooked ever since they arrived 6 months ago. From some of the demos I had too, it seems quite clear that the all Naim amp and cable arrangement does not work well with some speaker combinations, not in terms of what I want anyway. As already suggested it might just be it's not for you, at least not with your speakers. It's a cable that is quite clearly different in presentation to that I've used previously, and even when perfectly terminated can sound both pretty awful, and, thankfully, absolutely sublime depending on what you hang on the end.
