Muso QB Gone Silent (Mostly)
Posted by: Gavin B on 07 December 2017
I seem to be having a problem with my Qb. It's not working on iRadio or UPNP inputs. The ipod input is working fine.
The little LED is white suggesting it's connected to the network. I can see it and control it via the Naim app on my ipad but if i select iradio or upnp I get nothing.
For iradio, the while light around the volume dial pulses as if it's trying to connect, but nothing happens. I don't get any stream info displayed through the app. This is on more than one station (inc BBC). If I try upnp, I can add stuff to the play queue. The bottom status bar looks like its getting ready to start the fist track, but there's no sound. The track details appear in the bottom bar as if it's going to play, but then disappears. The volume thing gives the same pulsing as if it's trying to connect but presumably is failing.
Anyone experience anything similar?
Any ideas?
