Is the forum searchable ?
Posted by: Say-My-Naim on 11 December 2017
Hi, sorry, newbe here, is it possible to search the forum, sorry if this an obvious question.
Many thanks.
Posted on: 11 December 2017 by Eloise
Say-My-Naim posted:
Yes ... click the little magnifying glass on the navigation bar (Home... Music Room... HiFi Corner... etc line).  If you’re on a mobile device (at least iOS) Search is under the menu in the corner.
Posted on: 11 December 2017 by Richard Dane
Hi, welcome to the forum (please read through the rules when you have a moment, thanks). Yes, you can use the Search function which is via the little magnifying glass along the top header bar.
Otherwise, you can also use google.
Posted on: 11 December 2017 by Say-My-Naim
Wow thanks for quick response ....
Most kind
