Tellurium + Lumina
Posted by: Mort2k on 15 December 2017
Evening All
Just want to see the thought of combining Tellurium speaker cables with Lumina Interconnects ?
Now i am going active the timeline to buying 4 x 4m runs of Lumina Speaker cable is a long way of. Also I understand they dont do an XLR cable that would go from SuperCap to NAP250 making 'Full Loom' type usage impossible. Having tested and proven the benefits to myself of the Lumina interconnect and XLR i would not want to be without.
So would SL Interconnect + XLR + Tullurium Black2 speaker cabel work well together ? Anyone tried this ?
The other choice is another run of A5 for now and save for Lumina speaker cable
Rob
I have tried mixing TQ with SL cables and it just doesn’t work sadly. Also as you said TQ don’t make a cable from Pre amp to power amp making a full TQ loom impossible.
Agree with Finkfan
Mort2k posted:Evening All
Rob
Not so, Rob. I used an SL XLR between my 282/SC and 250.2 before I upgraded the 250.2 to a 300DR when I also needed to exchange the single SL XLR for a pair.
Mort2k (Rob), we have similar systems (only S/L DIN interconnect though), question, did you do your S/L interconnects together or individually, particularly keen to hear your (or any persons) impressions on the XLR as this is probably my next upgrade, I know S/L speaker cables is the most popular upgrade then followed by DIN/XLR interconnects for a full S/L loom. 5m S/L speaker cable is certainly up there in costs, although my listening impressions sure think it's worth the expenditure, but just to far for me, maybe 2018 ![]()
Paul
MDS posted:Mort2k posted:Evening All
Rob
MDS.
Sorry i meant Tellurium don’t do an XLR to allow a comparable full loom type setup. Hence needing to possibly mix
Rob
Mort2k posted:MDS posted:Mort2k posted:Evening All
Rob
MDS.
Rob
Ah! Ok.
Can't advise on your main question but I have used Tellurium speaker cable in the past with my Naim system and I think it works well.
Lifesabreeze posted:Mort2k (Rob), we have similar systems (only S/L DIN interconnect though), question, did you do your S/L interconnects together or individually, particularly keen to hear your (or any persons) impressions on the XLR as this is probably my next upgrade, I know S/L speaker cables is the most popular upgrade then followed by DIN/XLR interconnects for a full S/L loom. 5m S/L speaker cable is certainly up there in costs, although my listening impressions sure think it's worth the expenditure, but just to far for me, maybe 2018
Paul
Paul
I have done quite a bit of testing and can confirm all 3 cable types (speaker/interconnect/xlr) open up the sound stage I did notice that the XLR seemed to make more of an improvement than just the speaker cable. That said I liked the interconnect the most as a single option. Full loom seems to bring some synergy though.
Rob
How have you managed the lack of TQ preamp to poweramp interconnect problem in your system FinkFan?
Mort2k posted:Lifesabreeze posted:Mort2k (Rob), we have similar systems (only S/L DIN interconnect though), question, did you do your S/L interconnects together or individually, particularly keen to hear your (or any persons) impressions on the XLR as this is probably my next upgrade, I know S/L speaker cables is the most popular upgrade then followed by DIN/XLR interconnects for a full S/L loom. 5m S/L speaker cable is certainly up there in costs, although my listening impressions sure think it's worth the expenditure, but just to far for me, maybe 2018
Paul
Paul
Rob
Not forgetting a set of speaker jumper cables, for those of us with twin terminal speakers.
A touch obsessive maybe, but they worked for me. ![]()
I’d be inclined to get an NDS/555 before SL leads, especially if you are going active. Four SL speaker leads are a lot of money. I really like what SL does, and wouldn’t want to be without it. It was one of the reasons I chose a 300 rather than two 250s.
Mayor West posted:How have you managed the lack of TQ preamp to poweramp interconnect problem in your system FinkFan?
I use a hatpin 4x at the moment.
Hungryhalibut posted:I’d be inclined to get an NDS/555 before SL leads, especially if you are going active. Four SL speaker leads are a lot of money. I really like what SL does, and wouldn’t want to be without it. It was one of the reasons I chose a 300 rather than two 250s.
HH
That may very well be the route. Just like exploring options.
Rob
I use SL DIN to Din, standard DIN to XLR and TQ black speaker cable all sounds great here. I’m sure it would sound better with all SL but I have no complaints.
I also have three way speakers and use TQ black links. These made a nice difference over the standard PMC metal bars. Links aren’t available in SL I believe.
IanG posted:I use SL DIN to Din, standard DIN to XLR and TQ black speaker cable all sounds great here. I’m sure it would sound better with all SL but I have no complaints.
Tom Tom Audio can supply SL links, and though they're not cheap, I felt that they added something to the existing full SL loom.
Thanks that offers some hope
Rob
Finkfan posted:Mayor West posted:How have you managed the lack of TQ preamp to poweramp interconnect problem in your system FinkFan?
Hi
How did you find the hatpin over the standard XLR ? Significant stepup or a minor one ?
cheers
Rob
dave marshall posted:IanG posted:I use SL DIN to Din, standard DIN to XLR and TQ black speaker cable all sounds great here. I’m sure it would sound better with all SL but I have no complaints.
The SL links are a standard item on the Naim price list, for the princely sum of £999 per pair. At that price it might be worth asking the speaker manufacturer to internally rewire the crossover to avoid the need to use the biwire terminals, unless you feel confident to do it yourself of course.
Mort2k posted:Finkfan posted:Mayor West posted:How have you managed the lack of TQ preamp to poweramp interconnect problem in your system FinkFan?
Hi
cheers
Rob
A very minor lift in detail ime between 272/250DR. It’s a nicely made flexible cable.
GraemeH posted:Mort2k posted:Finkfan posted:Mayor West posted:How have you managed the lack of TQ preamp to poweramp interconnect problem in your system FinkFan?
Hi
cheers
Rob
As Graeme says a minor lift in all areas I felt. I didn’t expect too much for the price but I did feel it was value for money.
Thanks gents.
I hadn’t realised the links are available.
I need a 5m run of speaker cable so with the links that’s £5250 for me. I’m not sure the speakers cost me that much. I’ll stick with the TQ for now ![]()
