Atom Roon is playbacked via AirPlay. Is this wanted ?
Posted by: Rue on 18 December 2017
Hi everybody,
I fiddle around with some streaming devices using Roon.
I wonder, together with the Atom, that the Roon output shows Airplay. Is this wanted ?
cheers, Rü
Posted on: 18 December 2017 by Eloise
No, you should be able to play to your Atom using RAAT - Roon's native alternative to AirPlay.
Do you have the latest version of the Atom firmware?
Posted on: 18 December 2017 by Rue
Hi, thanks for your reply. I‘ve been told, yes, it‘s 2.0 at the Atom. I‘ve forced it to search for new software, but it says it‘s up to date...
i‘ve seen screenshots at the Roon‘s forum site where I‘ve seen the new Unitis are able ... what do I do wrong, still habe all Naim Apps updatet...
Posted on: 18 December 2017 by ChrisSU
The Atom should be on version 2.3 which was released in October, the main change being Roon support.
