Playlist
Posted by: robgr on 22 December 2017
I am using Naim app ver. 2.4 and it seems that the playlist behaviour has changed in that I used to tap the Album art thumbnail to the left of the play bar and it would display a vertical current the play list whereas now it displays a large horizontal playlist. However, if you scroll left or right to see the entirety of the list it starts to play the track in focus as it were. Am I going mad or am I missing something?
Posted on: 22 December 2017 by David Hendon
If you look at the top of the screen that used to be a list and is now a horizontal set of screens, you will see an icon in the top left corner. Tap that and it will change back to what you were used to.
I'm talking about the IOS app, but I should think the Android app will be similar.
best
Posted on: 25 December 2017 by robgr
Thank you David!
