Need I say more!
Naim debut it's Reference CDP with it's middle of the road Pre.
CD555>282>Snaxo>3 x 250>DBLs
Wow!
Allante93!
PS. The more things change, the more they stay the same. CES 2007
Hi,
I have recently sold my NAC 252/SUPERCAP/ NAP250DR System.
I’m looking to either go Active
NAC52/SUPERCAP olive
Snaxo 362/SUPERCAP
NAP 135 x6
or go for a NAC552 with perhaps a NAP300.
Any input on which will sound better?
The general advice is always to improve on the preamp but I have read the active systems absolutely blow any passive system away. Also how do I run the speakers can I purchase a normal speaker and have it modified for active use?
thanks guys
To my ears, a 552 sounds better than a 252
Active 135's (or 250's in my own case) sound better than a passive 300
I personally love the grip and control that only an active system can offer but, I have not heard the 552 / 300 combination.
I suspect it's got to be one of those things you try, if at all possible, for yourself.
active vs passive : well they blow away a passive in terms of bass control and articulation and also added clarity.
I'd love to hear a full Naim active system
But what a second I already have : Muso and Muso QB, and they are damn good music making machines
Been a while but I went active with 250s and spent allot of time and money trying to balance my system, in the end as many found best to heed the Naim advice source first (and pre amp).
I did not find going active was a massive step possbly for the reasons outlined.
You don't mention your source?
If you are all sold up I would wait (maybe a while) for the Uniti learning flow through to the classic range and maybe as a stop gap consider the Uniti range.
Having had an active system (52, 6x135's & Briks) and now a 552, 500 & DBL's I personally prefer the latter for shear speed, timing and musicality. Whilst there is in air of effortlessness about the active system it can't match what the 552 and 500 can do in convincing you that the musicians are actually in the room. I also found the active system harder to maintain, possibly because of box count, than the passive system. I know there are some who will argue the merits of the lesser active system, and I can see why but in my situation I went the passive path to maximise the musical 'bang for bucks'. Now, if I was to come into a little money I would definitely think about going active with 500's.
Khan, an interesting choice. Are you planning on keeping the Harbeths, or switching speaker as well? I ask because this might be a key consideration.
Best regards, FT
Thanks guys. Harbeths are also now sold. I was so convinced that I will definitely go active I didn’t consider keeping them. But the lure of the 552 has me thinking.
My source is a MacBook running Audirvana plus to a wyred4sound Recovery. Connected to a Berkeley audio alpha USB and then to a Schitt Gungnir Multibit DAC. This setup for source is one of the best I’ve heard at any price.
Also obviously a 552 is better than a 52. But is that a greater difference than the active 135s vs a passive 300 or a 250DR?
i only mention 250DR as I previously owned the 300 and the 250DR in my system beat the 300 in every respect.
The only way to truly find out is to listen to a passive vs active system in your own home. Not easy I know. I'm a huge fan of active, having used 2x250s/SBLs, 2X500s/SL2s, and now 3/500DRs/DBLs. But then I've heard superb passive systems in other folks' homes. Not terribly helpful, but it really is the best way to find out. You won't go far wrong by picking up a pair of SBLs or, if you can find them, SL2s; maybe a pair of Linn Isobariks? Audiovector speakers can be used active with Naim electronics, but the ones I've heard I've not cared for. I really wouldn't advise going down the road of trying to modify speakers not originally designed to be actively driven, it'll end in tears.
Khan, I’m not sure if you are aware, but with an active system you nend an electronic crossover that is set for the speakers you indend to use. So a Naim snaxo will work with Naim speakers and some Linn ones. Naim are also able to supply a version for use with active Kudos speakers. So you can’t just take any speaker, tweak it, and use it with Naim. Active systems are very revealing and so you do need a good source and preamp. One option, as you are starting from a zero base, could be a Naim preamp with some Active ATC speakers, say the 40A, or the 50A or 100A if you want something bigger. They have the electronic crossover and power amps on the back of the speakers, avoiding the need for a mountain of Naim amps. You may not like the sound of course, but it’s certainly an option worth investigating.
And the usual comment on active threads the snaxo can be setup to work with both Audiovector 3 and 6 series speakers.
Hungryhalibut posted:Khan, I’m not sure if you are aware, but with an active system you nend an electronic crossover that is set for the speakers you indend to use. So a Naim snaxo will work with Naim speakers and some Linn ones. Naim are also able to supply a version for use with active Kudos speakers. So you can’t just take any speaker, tweak it, and use it with Naim. Active systems are very revealing and so you do need a good source and preamp. One option, as you are starting from a zero base, could be a Naim preamp with some Active ATC speakers, say the 40A, or the 50A or 100A if you want something bigger. They have the electronic crossover and power amps on the back of the speakers, avoiding the need for a mountain of Naim amps. You may not like the sound of course, but it’s certainly an option worth investigating.
Khan
If you are thinking of ATC active speakers, you might like to consider ATC's SCA2 preamp which is in the same ballpark price-wise as the 252 (albeit that needs a SC). You'd get system synergy and balanced operation. I, for one would be interested to hear your impressions if you decide to audition such a setup.
Roger
Khan posted:Hi,
Snaxo 362/SUPERCAP
NAP 135 x6
thanks guys
Naim FAQ: What is an Active System?
"We believe that the best way to do the job is to intercept the musical signal as it leaves the pre-amplifier and use a powered [active] crossover (an electronic filtering network) to separate the highs from the mids and the lows. This, naturally, means that we need to use more power amplifiers: one for each band of frequencies. And more loudspeaker cables, of course: one from each amplifier to its dedicated loudspeaker driver connection.
This is, of course, more expensive than any passive system arrangement but we are convinced - as are many satisfied customers - that the results justify the additional expenditure. Active systems typically sound more precise, clear and controlled than passive systems. The result is music that sounds more like music and less like a hi-fi system. In part this is because active systems inherently produce less distortion than passive systems. [Sorry, for being technical but it's a fact!] "
I'm an Active Fan, if you ask me, it all started with Linn & Naim!
If I recall, DB had a kick ass Active System:
552>Snaxo 362>500> Briks
Just Saying!
Allante93!
PS. As Tonym said, try it out in your home, or just go out on a limb!
Trust me, you won't fall!
Khan
i have just done a similar journey and there is a thread on it called names something like if not SBL or S400 then what...
in summary for you here.
52/SC >NDX/XPSDR>SBL’s
order best to less good (could not say worse as the 250.2 is still great)
Active 2x250 (one DR)
Passive 300
Passive 250.2
The 300 was very impressive and a great amp for lower box counts. Active was just so engaging and instrument separation to die for.
Alos hears a demo of Kudos 707 the other month. Passive 300DR v Active 250DR. Again clear th emotion and ebagemnt from active won out over the 300.
Rob
I've run an active setup with SBLs for about ten years. A mixed bag of amplification as per profile that works very well (originally a 552 which I sold after a few years for financial reasons, a pair of 250.2s and briefly tried a pair of 300s).
Every now and again I get irrational ideas of maybe simplifying things and lowering the box count a bit, so I borrow a pair of of Neats or Focals or whatever my friendly dealer has handy. But nah, apart from most modern speakers being much too bassy for my liking, the system turns into a blandburger, life and dynamics gone up the spout and passive crossovers doing their obvious stuff. I'll keep what I've got.
Even so I wouldn't make a blanket recommendation for active. A few years ago I went to the home of a local manufacturer (in Aus) to hear their active speakers with built-in amps a la ATC and it was godawful, harsh and generally horrible. Whether or not it was the Class D amps I don't know, but I couldn't get out of there quick enough.
So, as always, there's no substitute for experience.
Khan posted:Hi,
thanks guys
You need to be able to either bypass or remove the crossover: easy if the speaker is designed for so doing (e.g. many ATCs and PMCs), but varying degrees of more difficult otherwise. You also need either to have crossover details to be set in the active crossover, easy if speakers for which standard setups are already available, e.g snaxos already set up, and not difficult if full crossover info us available including crossover frequencies and slope, otherwise varying degrees of more difficult...
Good question; Active vs. Passive....let’s look at what extra hardware is involved in an full house active system for a 3 way loudspeaker, done the Naim way;
That’s a massive amount of hardware and an aweful lot of money that could be spent alternatively. If spending all that money results in a system playing through DBLs or the very colourful (but highly coloured) Isobariks, I would suggest that the same money could purchase a system in an entirely different league with High end speakers and SOTA digital or analog front ends.
Who would have thought that having the wonderful opportunity to start over a fresh would be such a worry !!!
I'm sure we have all thought about selling everything and going in this direction or that...but reading this thread I can see it is a huge responsibility to get it right first time...not to gradually evolve like so many of us have done..
Good luck to you khan ...I hope you find what you are seeking
BLACKMOREC
which speakers would you suggest in preference to active DBLs ?
just curious
lyndon
Blackmorec posted:Good question; Active vs. Passive....let’s look at what extra hardware is involved in an full house active system for a 3 way loudspeaker, done the Naim way;
- an active X-over
- a X-over power supply
- 2 extra stereo amps or
- 4 extra mono amps
- 4 or 6 rack shelves
- 2 or 4 extra sets of speaker cables
- 3 or 6 extra interconnect cables
- Active-ready Speakers
- An optimised mains supply for all the boxes
The more fuzz the better, its a hobby in the end.
I'm currently building this system, to be completed in 2019:
NAS >> Nac 272 + 555ps >> Hicap DR >> SNAXO BMR >> 2x Nap 200 >> Ovators.
On the hifi side only 4 mains cables. Using the standard Naim Cables and some Naim Active Leads.
A friend of mine has made the solid shelves. I'm sure it's not as good as an official Fraim, but its rock solid.
I currently have a SuperNait instead of the Nac and PS, but I'm currently listening to them (Rolling Stones - Let it Bleed) and its fantastic. Especially the solid bass which does not seem to impact the treble negatively is what I much like. Its clean, transparent sound.
I'm thinking to put some Active SBL's in the Living room. Thinking how to do that, while re-using the existing stuff and be able to switch. Need another Snaxo for sure.
Love the Active Sound.
On the downside, something like Spotify is not really nice anymore. Better have a lowly system to listen to that.
Japtimscarlet posted:Who would have thought that having the wonderful opportunity to start over a fresh would be such a worry !!!
Hint!
Need I say more!
Wow!
Allante93!
Allante93 posted:
Allante93! Did Rudolf bring you a Snaxo for Christmas? Or will it be next year?
Ardbeg10y posted:Allante93 posted:Allante93! Did Rudolf bring you a Snaxo for Christmas? Or will it be next year?
Looks like next year, but japtimscarlet is point on!
Get it right the first time!
Waiting on an reply from NY US, SC has been Recapped, which is key when considering an unit more than 10 years of age.
Also one in the UK, has my attention, but after conversion cost (done by Audio Plus), and shipping cost, and recapping.
Me can't Do!
That's the deal breaker!
Age of units SN#s 191xxx, 231xxx, even 271xxx is not worth the hassel!
In the meantime!
Cdx2>282
HCDR>282
HCDR> 3 x 250.2> Briks
Perched upon 7 tier 2 stack Fraimlite, ain't bad!
Maybe not the Full Blown Aktiv System I lived with for 2 decades:
LP 12/ Ghenki
Kairin > Linn XO with Bingo Card
3 LK 280s, Dirrack PS and last but not least, my trusty Briks!
Allante93!
PS. I will keep you posted, if I pull the Trigger!
It all depends on the date, and who done the recapping!
I hate being particular, but I have had some close calls, buying Pre-loved Naim Gear!
Audio Plus have came to my rescue, when dealing with an Canadian Dealer, concerning an full warranty demo 250.2, which happened to be over ten years of age, wasn't disclosed!
Getting long winded!
OUT!
Ardbeg, I need both:
SC & Snaxo.
As you can see, I focused on this SC!
Allante93!
PS. Happy Holidays To The Naim Family!
lyndon posted:BLACKMOREC
just curious
lyndon
Depends what you're looking for. You could go for some exceptional 2 ways speakers paired with active subs, ala Magico, YG or Raido. Alternatively high efficiency, ala Tannoy or Avantgarde or you could look at SOTA 3 ways like Magico, Wilson, Rockport. A simple passive solution giving truly seductive sounds would be something like the SF Amati Homage.
Ok so I will have to go with an optimised speaker setup along with a Xover setup for that speaker and accompanying power amplifier setup. I have to agree it’s a daunting task trying to figure out which option will be the way to go for a better performance than what I achieved fro 252/SUPERCAP/250DR.
So if I went for the 552/ 1x135s in a passive setup. Do you guys think that is a marked improvement on my previous setup?
alternatively. A 552 and the slowly build up a stack of 135s or 250s for active system. Also please can somebody chime in on the snack versions. Are there any 2 way speaker option with 4 135s?
Apologies for the iPhone auto correct. That was 2x135s and snaxo
