Hi folks,
we are currently building a log cabin in the garden, about 10m away from the main house. WiFi reception is just about good enough for internet radio, but streaming from our uniti core (main house) to ND5XS (log cabin) via WiFi is patchy with dropouts, also when using the naim WA5 antenna. I’d be grateful for suggestions how to properly ‘feed’ my ND5XS in the log cabin! Currently I’m using a BT home hub 3 for WiFi in the house which works just fine. I see 2 options:
1) 30m ethernet cable (Cat6 or other?) between BT home hub and log cabin.
1b) And how about an ethernet switch at the log cabin side of the ethernet cable, so that I can connect the ND5XS, as well as a local WiFi router?
2) As an alternative to the ethernet cable, might it be sufficient to add a WiFi router to the system in the main house (e.g., Apple AirPort Extreme/Time Capsule) and position this in direct 'view' to the log cabin? (unlike the BT home hub, which is not on the log cabin side of the house). We have a large bifolding door in the log cabin, and the walls are timber frame, insulated with Tyvek air guard (silver foil). Would the WiFi signal pass through the bifolding door and/or the log cabin walls?
Many thanks,
Stefan
Posted on: 27 December 2017 by ChrisSU
You will need WiFi in the log cabin, if you want to use the Naim app to control the streamer. So you could try connecting a wireless access point and your streamer to a switch, and see if this will be enough to extend your LAN from the house. Then, when you get fed up with the dropouts, instal a cable, and you will already have the necessary hardware in the cabin readt to connect to it.
Posted on: 28 December 2017 by Stefan Vogt
Thanks, folks, so no concerns about a 30m long Ethernet cable (cat 6), then I go for this!
(I like the hose pipe idea, - thanks, Eloise!).
Posted on: 28 December 2017 by Simon-in-Suffolk
Hi Stefan, regular commercial grade Cat 5e is fine. Ethernet over twisted pair is specified to 100 metres on a single segment at 10/100 Mbps and 1Gbps. Remember Ethernet was designed to cater for distances more common in commercial setups rather the very short distances we have typically in the home and garden.
if you are going greater than 100 metres, and no repeaters, then fibre is the way forward , again very straightforward, albeit fibre adapters less common in consumer equipment.
if you bury, use a hose pipe that you cut up into 3 metre pieces (so you can easily thread the cables)... it’s what I do and gives the cables some protection... I have learnt the hard way....
BTW if doing a long run, use two cables or two/four fibres, this allows you some flexibility if you use suitable equipment at a point in time to load balance and provide resilience... again easy to do now, a lot of hassle to add later.
Posted on: 28 December 2017 by Huge
Go for a SFTP cable from a reliable source (such as BJC), although not needed Cat6 (or Cat6a) will give greater margin for signal stability on a longer cable.
Many Cat6 cables on the market even failed the Cat5 standard when actually tested (including ones sold on-line and ones sold by physical shops), hence the need for a reliable source for the cable.
Posted on: 28 December 2017 by ChrisSU
If you’re going to use conduit, I would use something rigid like Alcathene as hosepipe is easily compressible. Or use proper outdoor conduit that’s designed for the job. Make sure the ends are well sealed, or it is likely to fill with water over time, and can then be prone to frost damage.
Posted on: 28 December 2017 by Mike-B
Pev posted:
A Homehub 3 is nowhere near as good for wifi range as a Homehub 5 or 6, at least in my house. You can probably get BT to update you for free.
Spot on, my HH3 struggled around the extremes of the house, HH5 made it to the top lawn area, HH6 goes about double the distance maybe 35m from the hub to as far as I would normally use it where it works OK. - no need for wifi in the kitchen garden or paddock.
Yes talk to BT, they are open for deals at the mo.
Posted on: 28 December 2017 by phil. S
My cabin (office) is 25 metres from the house. I installed mains water, electricity and a toilet waste pipe so a trench was already dug for me to drop two runs of Cat6 in to. Everything works a treat being connected to my Synology router in the house and I have also created a WiFi access point in the office for phones etc. All my music is stored on a NAS in the office and piped to my hifi in the house with no problems at all.
