Naim olive tuner considerations
Posted by: booja30 on 28 December 2017
I've been interested in Naim gear for many years (since first seeing it in a local shop during college) and just recently bought a second hand olive setup (72/HiCap/140). I am really interested in finding an olive tuner to go with the set, and have been looking for one of the shoebox/olive models (NAT 01, 02).
My main question is about reliability and repairability. I've been reading a bit and people have mention FM 'heads' failing. Is this some component that was sourced by Naim, maybe with some ICs or logic boards that aren't serviceable? I don't see anything like that in the older 101s and I'm imagining that's just a variable capacitor tied to the MHz indicator. Can anyone recommend one model over the other if they wanted to keep it up and running for many more years?
One other thing, and I'm less concerned about this -- I seem to see Naim tuners come up far more frequently in Europe far more often than over here, which makes sense. The voltage change is fairly easy if the transformer supports it (I did it myself on the 140). But Naim mentioned a 'de-emphasis network' that needs to be changed from 75us to 50us (or vice versa) which from what I've read would only mean a couple of components swapped out. Has anyone done this or had it done?
Thanks in advance for any advice!
Problem is the rain washes it away
I found these aerial things worked best
