PS555DR
Posted by: zoot on 31 December 2017
My recently acquired 555psdr powering my CD 555 has shut down ,no power, worked perfectly last night this morning no good. Checked electric service and power line.
Seemingly no other problems with system, any way to reset ?
Posted on: 31 December 2017 by Harry
Fuse?
There is a spare in the unit. Fuse and spare in a pop out caddy adjacent to the power socket.
Posted on: 31 December 2017 by Finkfan
2nd that. Check the internal fuse
Posted on: 31 December 2017 by yeti42
Did you power it down and it wouldn’t come on again or did it fail overnight while it was powered up? The fuse is very likely in the first scenario but if the second whilst the fuse may be gone there might be another problem, you’ll soon find out if the spare blows too.
Actually this reminds me. When I power cycled my recently returned 500 after DRing it wouldn’t latch on again though the logo would light when holding the botton in. Sometimes the power button doesn't fully come out and it won’t latch again until it has done so, pushing it in a bit and letting it spring out did the trick for me but I needed tipping off about this one.
Posted on: 31 December 2017 by Bob the Builder
zoot posted:
Blimey!
Bob the Builder posted:
zoot posted:
Blimey!
Sorry couldn't resist.
Posted on: 31 December 2017 by zoot
Thanks for the help, Fuses next to power input looked ok did not check interior fuse!  switched fuses no good ?
Posted on: 01 January 2018 by Paul Quigley ie
Power line pushed in hard the full way?
Posted on: 01 January 2018 by zoot
OMG!, thank you all especially Paul Q , I didn't have the power line in all the way( I did not want to force anything) Duh, , yes duncehood is mine but I'm  delighted to have a working CD player . Thanks again forum everything's a learning experience!
Posted on: 01 January 2018 by spurrier sucks
zoot posted:
Lol. I've suffered the same fate. Glad you got it sorted.
