Happy new year to all. Especially to me, having just taken ownership of superuniti. chopped in my olive Naim pre/power hi cap for aesthetics (wife) and birds nest issues round the back. plus the streaming capabilities and Digital inputs.
Could someone give me some pointers with an issue im having. when selecting iradio and other inputs. It will display the station for 2-3 seconds and then the display switches to clock. I have been through the digital manual for setup and can only find display on off times but nothing
with regard to clock display. All i want is for the radio display to show the station constantly being played with info. if i select presets it gives too little time to select and i have to keep selecting preset to read the list. is this normal display behavior? If so, its a bit klunky.
any tips to keep the input daplayed until i change it would be most welcome.....
Posted on: 02 January 2018 by misterblister
Thanks Eloise, if I select clock when off to off. the display switches to a blank screen instead of the time, and I have tried auto off at the shortest to the longest time setting with no joy.
the issue I need to resolve is keeping the input and track displayed whilst playing.
Posted on: 02 January 2018 by Gavin B
The "i" button also determines what info is displayed.
Remember to set the display to go off at some point (rather than displaying the clock) to protect the screen, My Qute's display has 'gone' and now needs replacing.
It would seem to be the case that thevclock should not be always on to save the oled screen from failing prematurely. Ok, turned that off. Still have the original issue however with selected input only lasting 2-3 seconds before turning off.
Posted on: 04 January 2018 by misterblister
Problem solved, must have been a firmware issue. Factory reset cured the problem. Obviously the option to change the length of time for display to turn off was misbehaving. All good now and I can see what’s playing until I decide to change it.
