Supercap2, is there any use for it in a 552 setup?
Posted by: themrock on 03 January 2018
My current setup is Nac252, Nap300DR, Supercap2, NDac, XPSDR, Dali Epicon 6, Auralic Aries Femto.
My Supercap is about 11 years old, so next logical step would be to do a recap and the DR upgrade.
But in the medium time frame i would like to go from 252 to 552DR ( preloved)
So is there any use for the Supercap in that setup? Dont want to go active.
If not, i think i can skip the recap/DR upgrade.
Am i correct?
Posted on: 03 January 2018 by Richard Dane
If you don't wish to go active then there are two other possible uses for your Supercap; The first is to power a Headline or Headline 2.  The second is to power a phono stage such as a Stageline, Prefix or Superline.
Posted on: 03 January 2018 by themrock
Thank you, then there is no use for it amymore, if i will go to 552.
Posted on: 03 January 2018 by Ron Toolsie
As above....a dedicated SC is FAR better a supply than the 552 powered input...and when I ran a 552 I used a Supercap just for a Prefix phone stage- the powered input was way too sedate by comparison.
