"Rooms & Discovery"
Posted by: A funny thing happened on the way to the on 05 January 2018
Hi All,
I have read previous posts on this, as well as Phil's sticky to no avail and wonder if anyone can shed any light.
There are a couple of issues, they may be related.
Notes; there is only 1 wifi access point, one network, no POE.
System ; N serve Super uniti UniteQute x 2
I-phone IOS 11.2.1
Issue 1.
The Nserve doesnt appear as a UPNP device on naim app.
The N serve app had to be manually configured. I had to turn auto connection "off" and manually enter Ip address. When auto connection is on the app just "hangs" as it trys unsuccessfully to auto. I have downloaded the pro version of net analyser, but this seems to scan wifi and this device is connected by ethernet cable.
How can I "add the Nserve to the list of UPNP devices if not discovered?
I can access via desktop client no problem on a laptop that is wireless.
Issue 2
I have to manually add rooms to the naim app, nothing discovered. How also do I get to the "Rooms' page of the app? once i manually set up I i can t go back to select another room.
Once found, i seem to be able to connect once only, they cant reconnect to the device.
Thanks all !
