Cisco 2960 Recommendation
Posted by: NickSeattle on 09 January 2018
I see the latest compact 2960 switches boast powering by PoE, as one option.  Is this desirable in the Hi-Fi context?  The 2960 serving e.g. the NDX would not need a local power supply.
In an office setting, or, indeed, in the Living Room, this reduces clutter.  Is it a universal Good, or is there a sonic price to pay?
Nick
Posted on: 10 January 2018 by French Rooster
NickSeattle posted:
Nick
yes it has smps but it is very well built and costs new around 700GBP.  A lot of forum members have bought second hand, refurbished and factory reset for less than 60GBP on bay site.
model 2960-8tc and 8tl.     Try and return if not satisfied, a minority returned it. I kept mine.
Posted on: 10 January 2018 by NickSeattle
I am looking at WS-C2960L-8TS-LL at the Hi-Fi, powered by a -8PS or -16PS to deliver PoE, located close to the router.
is PoE power desirable?  It eliminates the need for a wallwart at the Hi-Fi switch, which sounds good to me, but is it the best way for a remote switch to be powered, for Hi-Fi purposes?
Nick
Now looking at 2960-CX series. . .  Lots of choices.
Posted on: 10 January 2018 by ChrisSU
It had crossed my mind that a PoE switch would be a neat solution in terms of keeping cables and socket use to a minimum. I wonder if there is a price to pay in having the signal carried in the came cable as the power (not that Naim have a problem with doing this in their amps.) I believe S-in-S has mentioned that he has experience of PoE switches, so maybe he will chip in with something more than just speculation.
Posted on: 10 January 2018 by Simon-in-Suffolk
Hi Nick yes the primary advantage of PoE in the Home I suggest is to keep clutter down, increase efficiency, and reduce the number of potentially noisy mid to low quality SMPS and reduce electrical noise on the mains.
i use PoE catalyst switches, but primarily as power sources for Wifi access points etc.
NickSeattle posted:
Simon is the person who recommended to this forum the cisco 2960 switch.  He had experimented the different models but found no real differences between 8tc or 8tl.  The cx, i think to remember, is the latest model. But you will hardly pay 50GBP for it....and not sure you will hear a difference vs the older model.
The majority of members of this forum had bought the 8tc model, refurbished and factory reset on bay site.  Of course you can buy a new last model, but you will pay around 900 k for it.
These switches are very well built and can live a lifetime....
Predictably enough, the newer models are supposed to be smarter/greener/more capable than the older models.
The L models have more ports and come either with or without PoE, and are described as “entry level”.  My old Netgear 24 port is about 10 years old, and was entry-level+1 at the time.  It can probably be swapped out for an L with PoE.  Then a CX without PoE can be a PoE client of the L.
I think I am on the right track.  Later maybe add a Meraki AP here and there.
Thanks very much, all.
Nick
NickSeattle posted:
Nick
i see on your profile that you have cd555 and ndac 555. What is the transport for your ndac 555? the mac mini?   how the sound vs the cd555?  i know, not the topic here, but just curious...
I bought the CD555, non-DR, used, during a market downturn, and consider it an excellent reference vs other contenders.  My system has been waiting for five years for a permanent home in an optimal basement space.  We are 12-18 months from realizing that improvement.
In the meantime, it lives in the Living Room at the top of a Fraim column, and  attracts neither criticism nor gasps of appreciation — it discharges duties with precision and humble excellence, which is all I ask.
Frankly, Audirvana+ via MacMini into nDAC/555DR is my best source; but the NDX is compellingly good, and more flexible and family-friendly.  I enjoy all of the options, and especially FM from the NDX.
Wife and daughter have forgotten we have rips on a NAS, preferring the Spotify/NDX experience overall.
My daughter’s High School Christmas pageant CD is the current resident of the CD555 — it sounds fantastic, and is likely to remain there into March.
The Naim app controls the NDX, 552, nDAC, and CD555, throughout the house.
I count my blessings daily.
Nick
