Best Match Phone Stage to run with Naim Nova
Posted by: Freedomsounds on 10 January 2018
I was wondering if anyone out there has any experience with which phono stage would would be the best fit for a Naim Nova &  a Rega Planar 6  w/MC Cartridge ?
Posted on: 10 January 2018 by Eloise
Rega’s own phono stages would be the obvious first thought, but I recently got a Arcam rPhono between my Project / Ortofon Qunitet and Naim NAC-N 272 and while I didn’t do exhaustive testing I’m very happy.
Posted on: 10 January 2018 by Adam Zielinski
I would trust Rega - go for the Aria if your budget allows.
Posted on: 10 January 2018 by Freedomsounds
Thank you Eloise, Yes, the plan as of now is to go with Rega's own phono stage. But was just thinking if there may better opinions for a better blend. What are some of your thoughts on the Rega phono stage ?
Yes Adam this the plan, to go with the Aria. Thanks ????
Freedomsounds posted:
Aria saw me progress from RP6/Exact II all the way to RP10/Aphelion. And it copes very well.
Posted on: 10 January 2018 by fatcat
Are you aware the nova converts analogue to digital, then converts back to analogue. Is it really worth investing in a high quality phono stage.
No, Fatcat I was not aware of that , but I am now  & its good to know. Thanks
Posted on: 10 January 2018 by Perol
fatcat posted:
Rega seem to offer a cheaper solution in the recent generation Fono MC as alternative using Ania MC
No wasted electronics either, smaller box, a wallmart psu but very much more affordable
You actually pay for two phonostages buying the Aria
No idea of the final compromise though
Posted on: 10 January 2018 by rainsoothe
Hi. I watched some review on the Aria which says the MM section is wonderful, but the MC - not much so. The guy rates the Avid Pulsus a lot in that regard. But, of course, do try to audition, as hearing for yourself is what counts.
Posted on: 11 January 2018 by Foot tapper
Another vote here for the Rega Aria.  It's simply brilliant value for money with a Rega MC cartridge.
Hope this helps, FT
Posted on: 11 January 2018 by Pev
Don't worry about the internal conversion of analogue signals - I use an LP12 with my Nova and it sounds very fine; certainly better than my all analogue Superuniti in the same set up.
As for a phono stage, I use a Naim Stageline which is a hangover from the days when Naim had a powered input in their pre amps. With the Nova you would need a separate power supply for a Stageline which makes it poorer value than the Rega alternatives.
Posted on: 11 January 2018 by fordy
I believe the ADC in the new Uniti’s convert the analogue input to 24 bit /48 kHz for the DAC to process from there on. I read that for the Atom anyway so presume to be the same across the range.
Posted on: 11 January 2018 by Freedomsounds
Wow, Thanks to all for your imput, this is a great help.
Posted on: 11 January 2018 by Timjoebill
Rothwell Rialto - great value and excellent performance.
