Splitting my equipment rack..
Posted by: Mike1951 on 11 January 2018
At the risk of opening another can of worms...
Space is a premium, so to solve the problem of having to site the rack between the speakers, I'm splitting it in to two racks of three shelves each (Isoblue 60), this will lower everything out of the range of the speakers and avoid the sonic reverb problems associated with the former arrangement.
As I understand it, the PSU's go on one side and the streamer, preamp and power go on the other, is that right?
(Puts on tin hat and ducks behind flack barrier)...
Posted on: 11 January 2018 by MDS
Pretty much, Mike. The idea is to keep the boxes with transformers away from the sensitive stuff like sources and pre-amps.  Typically the stuff with the latter goes on the left-hand rack (when facing the racks) and the boxes with the PSUs on the right, because Naim locate the transformers on the right-hand side of the boxes so this configuration maximised the distance.  The one of the left is often called the 'brain' stack while the one of the right is called the 'brawn' rack.  The ordering in each rack is often the source of much debate on here but that is fine-tuning and the rough split I've described is the main thing to do.
Posted on: 11 January 2018 by Mike1951
Power amp is "brawn"?
If it's got a transformer in it like the 200 or 250, yes.  If the PSU is separate, like the 300 and 500, that box counts as 'brawn' and the other one as 'brain'.
Ta.
Posted on: 11 January 2018 by ChrisSU
Having separate 'brain and brawn' racks will no doubt help in many instances, and the choice of which goes on the L and R is largely down to what enables the best cable dressing, as MDS says. Isoblue sits low to the floor, though, and this might make cable dressing awkward if all the boxes are very low.
Posted on: 19 February 2018 by Robiwan
A CD5si or Qute 2 (as streamer) also has a power supply build in, so is that a brain or brawn? And what about a Nait intergrated amp, brain or brawn?
Posted on: 19 February 2018 by ChrisSU
Robiwan posted:
They are both brain and brawn in the same box. The whole point of separate brain and brawn racks is that they increase the isolation provided by separates. You can'y increase separation that doesn't exist in the first place.
ChrisSU posted:
Robiwan posted:
okay. I have 2 fraimlite racks (base+level standard height). Which gear in the left and which in the right rack?
Robiwan posted:
ChrisSU posted:
Robiwan posted:
I think you will just have to use trial and error. Maybe start by putting the Supernait in the brawn stack with everything you use as a source on the brain stack, and take it from there. Perhaps give priority of isolation to your turntable, phono stage and associated leads, as these carry the lowest level signal, which is most sensitive to degradation. As I mentioned above, your choice may be influenced by cable dressing options as well as actual black box positioning. I generally try (on my single stack!) to ensure that all cables do not touch the rack, or any other cable, always giving priority to low level signal cables, and in particular, keeping these away from mains cables. It can take a bit of time to work out the best way to do this, and the best sounding result is usually not the neatest. Good luck!
ChrisSU posted:
Robiwan posted:
ChrisSU posted:
Robiwan posted:
My TT sits on a Pro-ject wall bracket!
