HiLine Question
Posted by: Mort2k on 13 January 2018
evening all
quick question where would one use a 4-5 pin HiLine ?
Cheers.
Rob
Posted on: 13 January 2018 by TomSer
Mort2k posted:
You can use it with DAC-V1 for instance.
Posted on: 13 January 2018 by Mort2k
Thanks. Is that all ?
Mort2k posted:
Probably not. I have one HiLine DIN4-DIN5 for my DAC-V1 but I guess there are other Naim boxes using this DIN4-DIN5 .
Posted on: 13 January 2018 by FangfossFlyer
I used one between my Naim pre-amp and Supercap that was powering my Superline.
You would need to check but it may also connect to a Hicap powering a Superline instead of the Supercap.
Richard
Posted on: 13 January 2018 by james n
FangfossFlyer posted:
That would work
Does it work from a 52 to a supercap. ? I don’t have superline
thanks
rob
Mort2k posted:
thanks
rob
I'm not sure what you are trying to do ? The 52 connects to the Supercap via a Burndy cable and a DIN cable (for the control circuits) ?
Hi
im just trying to understand it’s usage, got an option to acquire one cheap and wondering if it’s of any use in what will be an active SBL system.
Rob
Ah ok Rob - understood. Apart from the power supply to preamp connection when using a Superline (and the DAC V1 use mentioned) i can't think of any other uses for this cable so it wouldn't be much use to you in your planned active system.
Thanks James ????????
Rob
