For once, I too ask for advice. It's about small cheap loudspeakers. Thanks.
Posted by: Massimo Bertola on 14 January 2018
Hi good people of the Forum, happy Sunday.
I am taking my second system, the vinyl one, from 20th to 21st century so I have got rid, in a single stroke, of my Pioneer PL112D, SA-7300 and AR14s and have bought a very nice Linn Kolektor/LK85 combo and a Pro-Ject RPM 3 Carbon TT. The amps were a lucky casual find at a good price, the TT a careful choice based on heterogeneous factors. I now need a pair of speakers to match the Linn sonically, go into a bookshelf where the allowed height for them standing is 35 cm, come from the 21st century if possible, not have a rear port if possible, have a contemporary look and not cost beyond £300 to 400 (used or new).
If anyone have an idea that 'ticks all the boxes', as you say, thanks! I'll consider it gratefully, but please avoid (if possible) suggesting things from the early 80s, those garage-made-looking wonders that sound so good but are discontinued since ages and impossible to find, 11 to 16 ohms LS3/5As (I have just tried a pair by Audio Space and let's summarize it all with 'not a big deal' in my setup), Linn Kans of the first two generations (they'd need my Supernait to start making music) and things with unusual shapes: the speakers would only be requested to fit into a bookshelf, be professionally conceived and acceptably built and be happy with the Linns' 65W on 8 ohms and replay my (often 45 years old) LP collection pleasantly. Last, but not least, please resist the temptation to reply 'use the search facility' because I wouldn't (I already spend too much time looking at a screen). I just want a quick, simple idea from someone who has one ready.
The only exception to what I excluded are the rega Kytes, which I once owned and stupidly sold, and I know second chances are rarely allowed.
Thanks and best to all
Max
(P.S. I won't buy a 6th pair of Sats. They are not bookshelf speakers and I'd rather happily avoid ridicule)
Posted on: 14 January 2018 by Massimo Bertola
PP.SS. I have already spent hours on the web searching, comparing, trying to guess, tossing coins, reading reviews (man is a prostitute and a liar when it's about reviewing audio gear), reasoning and trying to revive my once working intuition. But I need some help all the same.
Posted on: 14 January 2018 by Adam Zielinski
Good morning Max
You my like the look of some of the bookshelf speakers from Monitor Audio. They seem to be rear-ported, but designed for shelf use though.
Adam
Good Morning Adam,
first note taken. Thanks,
Max
Posted on: 14 January 2018 by DrPo
Hi Max, I am using System Audio 705s in my office system. Vary agile and musical, price range within your specs but rear ported so some booming effect is unavoidable. I will be monitoring this thread with interest as I was wondering whether a sealed enclosure design might be appropriate for literally “bookshelf” speakers.
Greg
Hi, thanks. Don't know them, check immediately. Have a good Sunday.
Max
Posted on: 14 January 2018 by Huge
What is your listening priority
Resolution...
Dynamics (Timing / PRaT / agility etc...)...
Neutrality (when on a bookshelf)...
Ease of drive...
Something else?
If it's resolution, the Spendor SA1s are available s/h for just over your price (£425 - £450).
Posted on: 14 January 2018 by PSAN
Suggest you take a look at System Audio Aura 1. Modest dimensions, front ported (used to have a pair in my home office that were mounted on the wall, which worked well) and overall very capable speakers. Obviously not masses of bass, but what's there is very good and overall the rendition is fast and clean (but never clinical or boring). I've had many small speakers and in the "reasonably priced category" I think these are possibly the best I've had. Dali Opticon 1 may be worth a look too - Dali are typically good a low volumes too, if that's a consideration - but I haven't personally heard them.
Posted on: 14 January 2018 by alan33
Hi Max -
The B&W 6xx bookshelf speakers (in many incarnations over more than a decade) are front ported and often have brackets for direct wall mounting... Given their low price new (200€ for the smallest current model 686S2) and wide availability used (lots of old variants to explore), you might find something to get you started? I had success with very inexpensive original 685’s from about 2007 in a bedroom system hard against the wall beside a dresser drawer unit. Lotta love-it/hate-it in the B&W world of course, but for price, availability, and a decent sized used market, this could be worth a few more minutes searching in front of your screen (or driving around the usual places in your neighbourhood)...
Good luck and have fun!
Regards alan
Posted on: 14 January 2018 by yeti42
Totem Dreamcatchers.
They don’t tick your rear ported requirement but having heard them on a bookshelf it doesn’t seem to matter. Above all they’re fun and about the right price used.
For new speakers: Monitor Audio Bronze 2 are exceptionally well balanced, in budget, 350mm tall and front ported.
Despite being a ported speaker, they still work quite well when placed against a wall (front porting is absolutely no guarantee of good "close to wall" performance).
Posted on: 14 January 2018 by Folkman
The Rega RS1 was a later updated Kyte and retained all of the magic of the Kytes without the slight edge to the treble.
Note that I found the R1 was not as good .
Even though rear ported they will go as close  to the rear wall as you like. I had my pair as close as the speaker plugs would allow with no problem.
Guess they would be easier to find than a good pair of Kytes.
Posted on: 14 January 2018 by Innocent Bystander
Max height and depth, if on a shelf? Max width? (And of course, on a shelf around ear level speakers could be oriented horizontally...)
I don’t know if you’re aware, but there is one significant potential strength of shelf mounting: if you can arrange shelves all around - above, below and to the sides - to be filled approx flush with the front face of the speakers, you can achieve what is called ‘soffit mounting’, which removes the negative effect of rearward radiated sound reflected and causing comb-filtering when it interferes with the direct sound.
If I was looking for something within those parameters (though in practice with that budget I wouldn’t limit myself to 21st century), I’d be interested in finding out how the following sound - and these do occasionally crop up in that price range.
PMC DB1
PMC Wafer 1 (designed for on- or in- wall mounting)
ATC SCM 7
N.B. In case you haven’t come across it, HiFi Shark is a good web resource to use to search for secondhand gear, also allowing you to set up notifications.
Posted on: 14 January 2018 by Johnell
Neat Iota
Posted on: 14 January 2018 by wenger2015
One of the best small speakers, and very current is the Revel Concerta 2 M16, possibily a little over your budget but a pre-loved pair???
They produce a very detailed, open & dynamic sound, at last years Bristol Show they were in my top 3 of best in show, competing with speakers way above their price point.
certainly worth considering
Posted on: 14 January 2018 by james n
Max, As others have already pointed out, a lot of small speakers have rear ports which may be problematic in a bookshelf location. Something that might fit the bill for you and work well with your Linn electronics would be the front ported Linn Majik 109's.
To save you searching, here's a picture
Posted on: 14 January 2018 by Bob the Builder
I would imagine the Dynaudio Emit range would sound pretty good although over the 500 euro mark I would think new ex dem or used ones must be worth a listen.
Posted on: 14 January 2018 by Mulberry
Hi Max,
the Trenner & Friedl Sun would be nice, but is way above the budget. When it comes to affordable small speakers, the Zensor 1 and 3 from Dali have a good reputation.
Posted on: 14 January 2018 by JTB
KRK g6 passive studio monitor, front ported. Less than €400,- pp. Do not know if the poweramp is up for the job
If you are not to attached to the power amp there is also an active version.
Passieve 6 " Monitor
2-weg
Impedantie : 4 Ohm
1 " silk dome tweeter
Conus woofers gemaakt van glas aramide composiet
Frequentiebereik : 33 Hz tot 34 kHz ( -10 dB )
Gevoeligheid : 81 dB @ 1M / thomann 1W
Nominale impedantie : 4 Ohm
Crossover Freq . 100 W RMS , 400W Piek
Aanbevolen versterker : 50 - 150 W ( 4 ohm )
Ingangen: Terminal poorten
MDF kast
Afmetingen ( HxBxD ) : 332 x 226 x 290 mm
Gewicht: ca. 8,3 kg
Posted on: 14 January 2018 by cat345
I would suggest a pair of Sonus Faber Concertino. They are 8 ohms, front ported and beautiful to look at!
Posted on: 14 January 2018 by ChrisSU
Bob the Builder posted:
I thought about them too, but they are rear ported, so I imagine they need a bit of space around them.
Posted on: 14 January 2018 by leni v
Guru junior.
Hi all,
thank you for the many replies.
Huge, I have no special priority safe that the speakers don't turn out too lean sounding. My enjoyment of vinyl is, so far, still confined to an emotional plain and I don't expect imaging or HiFi spectaculars from two units buried among books.
Two mentions for the System Audio, which is a good thing because my dealer has some in stock and in store; and two for the Monitor Audio, which are a sort of underrated, ubiquitous classic. These are more difficult to demo, unless I go to my ancient dealer, who's in Torino, but there's Amazon, with a return policy (although I am developing something vs Amazon due to the damage it brings to brick and mortar shops and some rumors on their fiscal situation).
Folkman, I have had the Kytes and have heard both R1s and RS1s and I sincerely think that neither later evolution is as balanced, easy and listenable as the Kytes.
Thanks for making me aware of a few brands I ignored, such as Trenner & Firedl or KRK. The idea of the Concertino is also worth some research even though I was never a great fun of Sonus Faber; yet, they belong to the last era of good honest models from SF, before they became all shining enclosures and steel tops and yacht looks. So far, from a size, likely quality and good looks point of view I had thought of the Dali Zensor 3, but I have new ideas to investigate. As for my half joke on the 21st century, it's the simple wish to try and trust something conceived and built in an awfully consumeristic time, not relying perforce on the 'good ol' times' production.
The Linn Majik look the role a lot, but I fear they're way too expensive for a secondary system. It will take some time, or an unexpected lucky strike. Thanks to all, I'll now spend some time browsing here and there.
Max
Posted on: 14 January 2018 by Lanesra
I'd suggest getting a second hand pair of Heybrook HB1's.
They are a sealed box design and were designed to be installed close to a wall.
Wilmslow Audio make an updated kit version.
I don't know why there are so few new sealed box speaker designs.
Posted on: 14 January 2018 by Slim68
Huge posted:
I'll second this, My Son has these in his bedroom on the end of a Yamaha Mini System that is sat on a draw unit, they are not right up against the wall, but pretty close. He mostly listens to Classical music and these do a great job, they can rock to and are fun to listen to.
Good luck in your search.
Posted on: 14 January 2018 by Perol
I've had the Kairn/LK140 which was same amp module as LK85 but more powerfull, older Kairn preamp but higher up the hiearchy than Kolektor, not sure about age and service options ?
Friendly smooth sound, Not a bad combination indeed but guess easy speakers are preferred, ideal and perhaps developed together, would be bookshelf Linn Kan 3, Tukan, Katan etc but some are rear ported though guess they will, as RS1 work close to rear wall.
System Audio are great as are the affordable Dali Pico, Q acoustic 2010, older Royds, Wharfedale Diamonds, Monitor Audio etc, plenty of choice out there on the cheapskate.
