Cisco 2960
Posted by: Gazza on 21 January 2018
I have two Netgear gs108 gigabit switches in a daisy chain arrangement. Would it be best to replace both with Cisco 2960 8 TC or just the last one connected to the Naim Core and Nova?
Posted on: 21 January 2018 by Mike-B
I'm led to believe that daisy chaining is best avoided.
Posted on: 21 January 2018 by Gazza
I have no choice at the moment
Posted on: 21 January 2018 by Simon-in-Suffolk
Although there is nothing wrong with daisy chaining within reason, and switch to switch connectivity is part of good practice in larger setups, increasing the number of switches in a chain where there is no resilience is increasing the points of failure and ultimately affecting reliability.
If you want to try a Cisco catalyst switch such as the 2960, then have it closest to the audio network streamer such that it can make a potential difference
Thanks Simon, will do. Saw the Cisco switch in the Signals hifi cupboard, they got a bargain.....and a little help from your good self.
