Can I VLAN my way round Network noise?
Posted by: kevin J Carden on 21 January 2018
I’ve recently bought a DrayTek 2862 Firewall Router to try to get around a variety of persistent problems that seemed to plague me when using standard issue routers supplied by my ISP. Happily it has worked a charm - everything works reliably, speeds are obviously better and I’d even swear that the HIFi sounds better ![]()
I’ve also configured a separate switch (ZyXel GS1100-16) just for main system music so that only NAS, Unitiserve and the port serving the NDS plus a link to the router are plugged into it. I have not yet configured the LAN ports to create a separate VLAN for the port from the ‘music’ switch, but wondering if I do so I will succeed in isolating the music switch from any noise from anything plugged into the main switch, a ZyXel GS1100-24 which has 17 ports occupied taking Ethernet all around the house, a Rako lighting system, Apple TV, DVD player, Sky TV etc..
Anyone else done this? Did it work? All thoughts welcomed..
Kevin
