Nap 180 Flatcap connection
Posted by: jazzdream on 22 January 2018
Hi from Italy,
I moved to another house, and I need to set up again my Naim hi fi.
Since I missed the manuals, can anybody tell me which is the plug direction of the 4 pin cable? I don't want to make mistakes...
Thank you.
Alberto
Posted on: 22 January 2018 by Richard Dane
Alberto, the banded end goes closest to the source of the music - so in this case, for the SNAIC4 between NAP180 and Flatcap, it goes at the Flatcap end.  For the SNAIC5 between your pre-amp and Flatcap the banded end goes closest to the pre-amp.
Posted on: 23 January 2018 by jazzdream
Richard, thanks for the precious informations.
It works! Hope to find my manual (for the future)
