Dac to 252: which output to which input
Posted by: William on 24 January 2018
Lads I’m confused. Starting point:
I have my external DAC (Metrum Pavane) connected to my 252 via RCA to RCA.
Then, over on a streaming thread, I am advised that XLR to DIN sounds better (and is better) because:
“The single-ended outputs [on the Pavane] use Lundahl output transformers to convert dual-differential into a single-ended signal, whereas the balanced outputs are driven directly from the Pavane's converters...”
So I call my local Naim distributor to ask about the pros and cons of connecting a balanced XLR output to an unbalanced DIN input. Here is the reply:
“The best should be a SuperLumina cable 2RCA to 5Pin DIN.”
Can anybody shed any light, in particular on the following questions?
1. Is there any disadvantage in XLR to DIN given that XLR is the best output on the DAC?
2. Is RCA to DIN better than RCA to RCA and why?
3. What is best: RCA-RCA, RCA-DIN or XLR-DIN?
Thanks!
