How to play Qobuz download on NDS
Posted by: m.paul taylor on 24 January 2018
I downloaded a high res file from Qobuz and it will not play on the NDS. The file type is SMR.wma. Can anyone tell me how to make it playable?
Posted on: 24 January 2018 by Bert Schurink
On Qobuz you can choose many formats, so choose Flac and it will play.
Posted on: 25 January 2018 by m.paul taylor
Thanks - sorted
Posted on: 25 January 2018 by French Rooster
m.paul taylor posted:
i made the same error first when i bought the nds.  Wma doesn’t work. You must choose waw or aif format.
naim streamers prefer waw to flac.  but i havn’t seen the difference in sound.
Posted on: 25 January 2018 by Bert Schurink
French Rooster posted:
To me there is a significant difference between Flac and Wav that’s why I have Flac on my NAS but I ensure it get’s transcoded to WAV before it arrives at my NDS, like a lot of others do, the best of two worlds....
Posted on: 25 January 2018 by Harry
I haven't seen a difference either. But I have heard one. And it's a big one. If you can't hear one, it simplifies your situation considerably.
