USB cable advise!
Posted by: 999inmydreams666 on 26 January 2018
Hello....can anyone give advise for a good neutral usb cable (regardless of electronic in use) which has great midrange crispness/attack (no soft edges and lazy warmth adds) and goes along with naim sound philosophy ?
what do you guys have in use not to mess with naim tonal balance ??
thank you!
Posted on: 26 January 2018 by james n
Try the Chord Silver Plus USB (i think it's now called the C -USB)
Posted on: 26 January 2018 by M37
Nordost Heimdall 2.. fast and crisp with a lot of details.. My best upgrade. I find it works particularly well with my Chord dac
Posted on: 26 January 2018 by Jude2012
Very difficult to translate descriptions of music replay as everyone hears and describes things differently.
So, If able to,  source from a shop ( there are few online stores) that lets you return the cable if not satisfied.  I would add Wireworld  and Audioquest to the list.
A snug fit of the connectors is as important as any of the approcaches (I.e. shielding, silver coating, purity of copper, no 5v etc etc) taken by different brands to produce an ‘audiophile’ USB cable.
Posted on: 26 January 2018 by 999inmydreams666
M37 posted:
ok...I've got the full red dawn range for the rest (power, interC and speaker) but I'm trying NACA5 next week as nordost has good harmonics but too much seem to kill attack and crispness. I've got purple flare as usb but I don't like that much as it reduces micro information a little compared to "standard"!
james n posted:
thing is I need usb to mini usb connector unfortunately
Jude2012 posted:
how is wireworld / audioquest sound??
I tried a number of USB cables back 2013 ( the post is on the forum). There are others brands on the scene now too.
I choose the Wireworld Starlight 7. It was between this and the Audioquest Carbon.  To my ears,  my system, and my listening room - the Wireworld hit the spot.
Audioquest has a reputation of being ‘neutral’, as I said though, this means nothing until you test any cable out in your actual set up.
Some folk are happy with using cables that come with a printer and the like.
Posted on: 26 January 2018 by aht
The Vertere D-Fi cable (their least expensive line) is very, very good.  Don't know if you can get it with mini-USB, though.
Jude2012 posted:
I was reading differents reviews on the wireworld and they all say it has that "rounded" warm midrange which I do not prefer.....I'm looking for a "drier" sound...maybe the carbon????
Posted on: 26 January 2018 by p.
I use Analysis Plus Purple Plus USB cable, for my ears it is neutral and musical, I enjoy having it in my system more than any Audioquest USB cable I have tried.
Posted on: 26 January 2018 by cat345
I use Curious Cables between the Intona and Chord Hugo and I find it better than the cable that Chord provides. I don't think the kind of USB cable between my laptop and the Intona would make any difference.
Posted on: 27 January 2018 by M37
I’ve tried numerous different brands and countless generic printers usb and they all sound different.. so it can be tiresome
Nordost was best to my liking suiting my system and room. Nordost Blue heaven is fast but a little thin.
Chord Signature came close. Very detailed with more low end comparing to Nordost.
Shunyata also sounded good, perhaps a little dry and impossible to route.
TQ Silver is highly praised among hifi critics so perhaps have listen to TQ? And there’s also Oyaide.
