Uniti Atom HDMI ARC Testing Weirdness
Posted by: SB955i on 29 January 2018
Hi Everyone,
I'm not up to speed with HDMI ARC and audio format constraints if any.  I have something weird going on and wondered if someone has the knowledge..
I'm just hooking up HDMI ARC for the first time for testing.  I wanted to ensure the ARC card was working ok after purchase. I'll use it in the future one day when we downsize, but it won't be used for a while.
My test 'lab' is a Uniti Atom, hooked via HDMI ARC to a Panasonic TCP50GT50 Smart Plasma TV.  IT has an HDMI ARC port and uses 'Viera Link' nomenclature for setup of that port. The TV is networked and sees a number of DLNA servers ( Music, Movies on a QNAP, the NAIM), a HDHomeRun DLNA OTA tuner, and it also has a Netflix app.  Everything works fine through the TV speakers.
Here's what I've found:
DLNA Music - everything works ( on/off,volume, HDMI input focus ), music comes through
DLNA Movies - everything works, sound comes through, controls work as above
HDHomeRun - I can hear sound in DLNA preview (DLNA browser on the TV), but when I 'select' the channel, the sound changes to a mid-frequency 'bad ignition coil' sound. Control functions work ( on/off, volume, hdmi focus)
Netflix - Control functions work, only get the ignition noise sound.
I read over on the HDMI website, that HDMI cable shouldn't matter.  I've tried two, made no difference.  I've looked to see if there are ARC audio settings to change outgoing encoding or something on the TV, but no it doesn't. Also looked for audio channel control on the HDHomeRun and can't see it there either.
Anyone have any ideas?  I figure it's an encoding issue, but can I get the details? Much appreciated
Posted on: 29 January 2018 by Eloise
SB955i posted:
HDHomeRun isn’t sending a Dolby Digital or DTS signal is it?
Posted on: 29 January 2018 by SB955i
I can't really tell as there's not much an interface to it. I tried all the channels and they didn't come through.  Is that what it sounds like with that encoding?
Check the TVs settings, you can probably set it to use 2channel PCM digital output or Dolby multi channel output.  Sorry can’t point you where the setting may be but look under Vierra link settings.
I need to figure out how to get status of the stream somehow.. digging in..
